I think aftermarket solid rollers are built like a hour glass, right?
Mine are solid body, no cutouts, but short.
LOL... "wild" was your word. I said "rev and likes to move it move it". Most look at 318's as 14, 15, and 16 second engines that shift a 5 - 5500 rpms. I think a streetable 318 on pump 91 that starts at 12.99 and goes Southward and shifts Northward of 6k is a "scream'n teener". Especially if the budget stays well South of 2k.You are sticking to your roots. lol
The OP started out wild and is starting to lean towards mild. lol
I'd like to see at least 11.5 compression. lol
whatever you build it will run to it's potential, we know that.
I thought about that too, but both blocks are rollers, so I thought that would be the right thing to do....A nice flat tappet solid will do the trick. lol
and be turning 8200 rpm threw the traps!!Here, I can clear the air of one thing. If somebody is waiting for me to build a stock-stroke 318 to pull the front wheels of an all steel Duster past the 330 ft marker and click off a 9.20 run @ 150, LOL, please don't hold your breath...
Right! Keeping it realistic, this 318 will hands down ground pound the "low dollar under 500 318".and be turning 8200 rpm threw the traps!!
I just want you to have enough compression to run any cam you want.Here, I can clear the air of one thing. If somebody is waiting for me to build a stock-stroke 318 to pull the front wheels of an all steel Duster past the 330 ft marker and click off a 9.20 run @ 150, LOL, please don't hold your breath...
Solid cam, roller would be better. Good springs, roller rockers big cam. But wait, the 273's liked to rev and they did it with stock parts and none of those parts were real racy. Dual point may be. Cam was mild, 4 barrel was small exhaust was restrictive, cam was a solid flat tappet but all the 273 cams were back then. Ya and they revved to 5500 and not past 7-8 like the tales that are told. LOL
not if he already got most of it!It's going to take more than $1500 for a 450 HP 318
Here are some of my thoughts, the "what if's". LOLIt's going to take more than $1500 for a 450 HP 318
I'm pretty sure this will happen. I really want make these extra parts into complete, running engines. Time is a big thing. I work full time, active in our church, home-life and the cares of life. Also, putting together youtube videos. YouTube has been an absolute joy to this hobby for me, the guys have been great there. Unbelievably supportive and fun.hope you do get this built!!
Considering building a 318 that revs and likes to move it move it! I've got options for heads, roller block. Maybe a Victor 340 intake... I already have a built 904 ready to go with RMVB.
Oooook, well, it makes a little more sense now. I saw the title of the thread and thought you were actually building something....you know....Fast (scream'n)....like a 10 second 318 that spins up in the stratosphere. Then I saw that you were looking at stock iron heads and the word "fast" went right out the window, lol. Still, sounds like you will have a spunky little 318 that makes good steam.Here, I can clear the air of one thing. If somebody is waiting for me to build a stock-stroke 318 to pull the front wheels of an all steel Duster past the 330 ft marker and click off a 9.20 run @ 150, LOL, please don't hold your breath...
It would be roller cam. I have the roller block, it only makes sense at this point
I know you asked 318WR, but my personal 2 cents is spend some money on good heads to couple it with a solid roller and you’ll be way way ahead of the game.What's your opinion on those roller cam 318s, with 302 heads, as opposed to the earlier 318s? I've got one I'd like to do the same high revving build you're doing. I think they all need help breathing, to start.
The #302's have a small efficient chamber but not much more port flow than any of the 273/318 heads.What's your opinion on those roller cam 318s, with 302 heads, as opposed to the earlier 318s? I've got one I'd like to do the same high revving build you're doing. I think they all need help breathing, to start.
If stock heads are the sticking point and all you have are 328 heads, your behind the 8 ball and I’d start looking at some restricted racing classes & how they do it. A fella that knows a little something about it would be @Hysteric and a few other members who’s names are escaping me right now.
