Matts440
I know they are a bit pricey but vibrant performance sells good quality ones
X2 on ditching the flex fan. They are junk, throw blades and contribute to, not solve, overheat problems. You would be way better off with a factory shroud and fan (preferably the big 7 blade one). Try the wrecking yards, look on the factory early 80's volares and aspens etc.
Well I glassed the trunk, ran my wiring, installed the new Moroso battery box and vented it to a hole in the trunk floor, and bolted my tool boxes to the floor. Looks pretty darn good back there now.
Another stealth subwoofer install complete.
Looks great!!!! Nice job!!! Love those low-frequency sounds... Do you use a crossover network in that system?
Thanks!
Yes I do. There's a crossover built into the head unit, and I also have one in each side of the dash to allow two tweeters and the door speakers to function without putting out lower frequencies. There's also a low pass built into a digital amplifier so the subwoofer only picks up 80hz.
Looks awesome. What make of seats?
good to see progress even if its just fixing normal issues. are you going to spring fling next weekend?
A new friend a couple blocks away (who has a valiant) was telling me there was a big Mopar show coming up. I believe that's what he was talking about. I would love to go. I have to get the car running. I am registering it for the local car show on the 26th because I know it will at least make it that far in its current state. I hope this issue is solved soon because I'd like to hit the spring fling.
