I think I would hang the fenders, bumpers, install windshield and take her for a few rides. Nothing like experiencing what you've built a little to give you some extra motivation for all the other assembly it still needs.
Southern Ontario doesn't have quite the same weather as California. There is a couple of feet of snow on the ground!!! I've had it up on blocks and run it through the gears up to 60-70 mph, so I know everything works OK - just didn't feel the wind in my face!!!
I'll have it done by spring and get it out on the road.O
Great looking build! Do you have the part number for the Wizard rad assembly?
This build thread has been such a big help Would you mind if I link it on my website and use some pictures of yours?
I am building a GEN III Hemi swap database website and this is just a huge wealth of knowledge. It would be great to share!
Have spent many days getting all the windows aligned with the top. Plus trying to figure out all the adjustments on the top. Man, this is complicated!!
I then hung both front fenders and started to get all the gaps aligned. Then found I had to pull in the front of the pass door a bit to get a good alignment between the fender and the hood.
This should be pretty straightforward - just loosen the hinge bolts on the door and push it in a bit, but it wouldn't move!! Then I saw that the edge of the hinge was hitting the inside of the door. (Which means it was never right from the factory)
Off comes the hinge to do some grinding. I have to reassemble everything so hope this will work out OK.
Of course this means re-aligning the pass door window with the convertible top seal!!!
can you make a spacer for the post hinge, then you can move door in and out
Thanks Joe. I agree, some cars just look like they were thrown together with really bad body gaps. On the other hand, some cars are over restored and have perfect gaps, which didn't happen on the '60's and '70's and probably '80's assembly lines!!Getting everything to line up is a real challenge. I've seen a lot of cars with crappy body gaps, you'll be glad you took the time to get it right.
Keep up the good work,
Regards
Joe Dokes
Passenger splash shield installed. Fender tab and bolt blacked out like was done by the factory so that the blue coloured tab is not visible when looking at the vehicle.
I used some more Eastwood acoustic pieces to cover the holes in the doors before adding the plastic rain shield and the interior trim.
Another one of your posts that make me say "shoulda, coulda, woulda done that" to the restos I have done before. You and your car are just a classy act.
The door looks so good if it was my car I would have to sit in the car just to check out that door!
Well, you are almost done, and I think you just got your last snow of the season too. :blob:
