bluefish
mopar dave
Yes, as i said before, the 4.10 would be your best street/strip gear. I had a 4:30 with a 28" tire and i hated it. The performance was no better either. I like the fuel cell. Do you know if there is a fuel cell available with baffles to prevent fuel flow away from pick up on braking as i have the same problem with 3 gallons of less in the cell?Got the new fuel tank mounted in the trunk and have been out driving the car. I really like how it drives with the 4.10 gears. The 4.56 gears were just too steep for street driving but the 4.10 gears seem to be almost perfect. The new fuel tank works nice also. No more sloshing around and the gas gauge stays steady now rather than going up and down with each corner. The built in sump allows me to run the tank down to empty. Before with the flat bottom fuel cell I couldn't run it below about 20% before the fuel would slosh away from the pickup.
