boosted
Life Needs Air
I need to try and figure out where these parts goe. i can see the dogs and pins, the rubber seal and clip.. But what are the items on both ends of this pack and where do they go?
I must of missed the pin. I don’t think mine had one.
I think I've seen some discussion on this (here?) with pretty good evidence the pins were added after 67I must of missed the pin. I don’t think mine had one.
That is the most complete column renew kit I have ever seen. Where did you buy it?
I'm almost certain my 67 had the tiny pin in place also. I don't think I ever serviced a coupling that didn't have that pin. All were 67 and later though.Me? If so Detroit Muscle. Oh and my car is a 67 with the small pin... Go figure that...
No doubt. I ended up pulling the column out of my 66. Way easier to replace the lower seal/ bearing that way.Good luck on that huge pin on end of shaft. That thing dont come out! Would be nice to R&R the lower column bushing/bearing without pulling the entire shaft. Save the pre-65 rectangle coupler box shoe spring as the new one wont fit.
