Stop in for a cup of coffee
About a hundred years ago... At the antique shop we got the stuff in 55 gal drums. Kept in a shed at far end of building opposite from where we used it. I was transferring some to a bucket and splashed down front of my pants. Fastest I ever stripped to my skivvies and ran around to the other side behind the building. Boss lived next door, I think he loaned me a pair of pants. LOL
Another product that works great Banned! Contact cement, Banned in CA. Lacquer, Banned. Jabsco, wood preservative, Banned. Green lumber, Banned.....on and on and on.....
so I've not been able to figure out if that stuff I posted has that chemical in it or not
Common Name: AUTORF 1-GL 2PK AIRCRAFT RMVR 0110, 255447
Manufacturer: RUST-OLEUM
SDS Revision Date: 5/18/2015
SDS Format: GHS-US
Item Number(s): 4YLF1
Manufacturer Model Number(s):
HAZARDOUS SUBSTANCES
CHEMICAL NAME CAS-NO. WT.% RANGE GHS SYMBOLS GHS STATEMENTS
DICHLOROMETHANE 75-09-2 75-100 GHS07-GHS08 H302-351
METHANOL 67-56-1 10-25 GHS02-GHS06- H225-370-311-
GHS08 331
C9-C11 ALCOHOLS 68439-46-3 2.5-10 GHS07 H302-315-319
ETHOXYLATED
HYDROTREATED 64742-47-8 2.5-10 GHS06 H331
LIGHT DISTILLATE
Yep - Dichloromethane is same as Methylene Dichloride
Damn hippy liberals
LOL. but nah, they played with all that dangerous stuff too.
More like the currently large crop of coddling, overprotective, busybodies. Many so called conservatives are as afraid their boogymen as the so called liberals.
Ok...I know I need a right front lower control arm for my Truck. I pulled it inside, put didnt put it up yet. Figured Id try to find a control arm, before I take it all apart. Seems they are pretty RARE...... 92 D250 2WD #4000 Axel, Right Lower Control Arm....Any Help Here ???????????????
LOL for sure. I can't imagine. Bad enough when I spilled a turp mix on on a pant leg ..... doesn't burn on the hands but does where there
s some sensitve skin .
Did you guys also use lye by the barrel?
If they totaled it, are you able to keep it with a clean title in MD?
SDS Format: GHS-US
GHS08 331
ETHOXYLATED
LIGHT DISTILLATE
sweet, i'll be sure to grab the remaining 2 at the local store lol
No lye that I recall. Just that at that shop. Set up like a giant parts washer. About a 5x10ft 'tray' with a pump running straight stripper up through the brush. Scrubbed the finish off and took it outside and hosed it off in the driveway. :eek: Another shop I worked at, we had a tank about 6 x 12 and a couple feet deep. Filled with 50/50 acetone and laquer thinner. Put the whole piece in and roll it around till the finish loosened. Then brushed it off. Take out and wipe with fresh thinner. No I didn't sniff any fumes. :realcrazy: Seriously, Both places were ventilated good, but no way you didn't absorb some of that. Glad I didn't spent too many years in that line of work...
