I need #4000 lb axel....Plenty of #3300 ones out there......yikes, noted to grab any I see at local junkyards
Try Carpart.com. Car-Part.com--Used Auto Parts MarketRight side, Lower. 92 D250 2WD....... not 4WD....Has #4000 lb front axel. Parts are more available for the #3300 Axel....
it is ,i love itLooks like a well run site.
Thanks, I'll check, Mike...Try Carpart.com. Car-Part.com--Used Auto Parts Market
Looks like they have a few listed. Waiting for the guy in Indy to call me back. Then Ill make more calls, Thanks, againTry Carpart.com. Car-Part.com--Used Auto Parts Market
Yup if they have it. I just talked to my Sherwin Williams guy it all had to be pulled from the shelves on the first. He has no idea why
Just found one in NY...$100 shipped...should have it Friday...Thanks @toolmanmikeLooks like they have a few listed. Waiting for the guy in Indy to call me back. Then Ill make more calls, Thanks, again
probably a company policy thing to start with. Local paint store still has it, I called earlierYup if they have it. I just talked to my Sherwin Williams guy it all had to be pulled from the shelves on the first. He has no idea why
You bet. Hope your save works out well.Just found one in NY...$100 shipped...should have it Friday...Thanks @toolmanmike
Be realistic. Do you use it?sweet, i'll be sure to grab the remaining 2 at the local store lol
I use about a gallon a month. Works great getting crusted on grease/oil off of parts.Be realistic. Do you use it?
I do. But not often, and not that much. A gallon can be sitting here for several years - usually longer. By then someone is cleaning house and I get another gallon or quart. If the cans are just going to sit in the shed getting rusty, its just a waste.
Grabbed too much , last 2 Months......Grab as much as you can now.
and give it to Ray.Grab as much as you can now.
You're not Chris!I use about a gallon a month. Works great getting crusted on grease/oil off of parts.
Bet he will mix it in BEET juice! Prob need five for the polara though.....You're not Chris!
yes. and i have 2 project cars to do eventually.Be realistic. Do you use it?
I still have 4 large airesol cans....yes. and i have 2 project cars to do eventually.
