Stop in for a cup of coffee
Made mulch this morning
@MOPARMITCH
If you trip over steering knucles,grab them. They are likely harder to find. Blow a wheel bearing and it kills the knuckle.
Glad you found a control arm.
Stopped for lunch, everything tastes like burned clutch. Dont know why...
@MOPARMITCH
Yup, Thanks Frank...Usually on 4WD...This one is 2WD....
Wow, the HF sandblast cabinet is marked down from $179 to $139 with a 20% coupon. $111 and small change. Glass bead, black aluminum oxide or soda for GP and aluminum?
I use glass. It turns to flour abd still works. Flows better i think. Unless the air is wet...
Had a 2wd in/near shop last summer. Didnt know what was going on, he figured he drove 5-6 miles on blown bearings and demolished everything. Caliper too. He found spindles in montreal.
It disintregated when i pulled disc. Smart enough to put a garbage can under it though...
I must need to put louder mufflers on my cars. Every Harley and pick up has been flexing their muscles this afternoon.
Speaking of muscles- I'm beat from doing that mulch. Should have stopped halfway through and saved it for another day. Just too much before a full shift at work. I rarely take a nap, but I could crash right now. 6 more hours to go.:BangHead:
Trans back in. I has to at least get mount back in so it no fall down overnight. Hoist is on locks, but trans jack is holding up trans and engine. Was a tough go but it splined right up once i got it close.
