Have Tim swing north and pull the teen out for Ramie's friend.Depending on your timing, talk to Tim. @Mopar Tim He said he is going to swap out the 318 in the ‘66 after he comes and gets it. It runs great!
Well of course you did. Most of the folks there are fairly slim. A much better diet I am sure.Hey.... I lost 15 lbs in two months, and wasn't even trying.. Today the Doc asked me, if I also exercised/workout in Viet Nam.......I said.....Uhhh...Yeah Sure.....
A bigger pain. Have your front end aligned with less caster if that's possible.Ok, another question for ya. This is on my own car, I was thinking of swapping the factory manual steering box to the PST 16:1 box. I do not have the factory steering wheel and if memory serves me right its only a 15" wheel. Do you guys think the 16:1 box would be a real pain in the *** at slower speeds, such as parking?
Do you work out?Ok, another question for ya. This is on my own car, I was thinking of swapping the factory manual steering box to the PST 16:1 box. I do not have the factory steering wheel and if memory serves me right its only a 15" wheel. Do you guys think the 16:1 box would be a real pain in the *** at slower speeds, such as parking?
Slower speeds...parking NO FUN!!Ok, another question for ya. This is on my own car, I was thinking of swapping the factory manual steering box to the PST 16:1 box. I do not have the factory steering wheel and if memory serves me right its only a 15" wheel. Do you guys think the 16:1 box would be a real pain in the *** at slower speeds, such as parking?
a. Yes.I've got a couple questions..
- If I recall the slant trans (assuming it has a 904) has a different bell housing pattern than a SBM trans correct?
- He said his car has dual exhaust but how much of that would have to be change to make it work with a V8?
- Does anyone have a good lead on a 318 engine and trans. Or even a good running slant incase he wants to go that route?
Finally she can pee in the woods!!
Get the “pump it down” mod kit. It cuts down the power steering by about 50%Thanks everyone. My car came with power steering and I believe the wheel was a couple inches bigger. Maybe my Grant wheel is only a 13"...
I was debating about swapping back to power steering since my manual steering is so sloppy and loose feeling, but I wasnt sure about going to that ratio. I figured it would be a work out and no fun and I would hate it. I have everything to swap back to power steering, but not sure I want to...
I need a break! LOL
Thats a good idea. I just want to have the car more enjoyable to drive so I have been trying to figure out what way to go..Get the “pump it down” mod kit. It cuts down the power steering by about 50%
LOL, holy crap buddy! Yes you do!!! Are you a mod on everyone of those sites?I need a break! LOL
My sequence of checking is:my manual steering is so sloppy and loose feeling,
Is that a handle bar mustach she,s sporting, under them bottoms ??????
Its all in the steering box. I've adjusted it last year, but over the course of the summer it got sloppy again. Now Im out of adjustment. The entire front end was rebuilt and everything good and tight.My sequence of checking is:
Wheel bearing adjustment - check with wheel off the ground, grab and 12 and 6 and see if there's any movement.
Check for movement in the linkage - leave one wheel down, grab the other around 9 & 3 while watching steering linkage for slop. Then do the other side.
Both wheels on the ground, turn the steering wheel looking for slop between the coupler, and then looking underneath at the pitman arm.
Not e bodies.LOL, holy crap buddy! Yes you do!!! Are you a mod on everyone of those sites?
Just fit in the trunk standing when placed near the hinge.
