Yes....Getting building material together to start on new work area. With a lift!! I deserve one... Now, 4 post or 2 post? Big question...Summer time buddy. People are out and about.
Hope your doing well. Sounds like your keeping busy as usual.
As someone with a two post, I would recommend a 4 post.Yes....Getting building material together to start on new work area. With a lift!! I deserve one... Now, 4 post or 2 post? Big question...
Yeah. I like my two post for a lot of reasons but the biggest reason I would switch is simply due to stability of the vehicle while on the lift. I’ve got a 12k commercial rated one and little vehicles like my Jeep or the wife’s Durango are just fine, but man, I put the truck on there and no matter how much I try to center the weight, it’s still rocking pretty good. So I installed safety chains with booms to stop itAnd just to muddy the water, as someone with a two post I will never go back to a 4 post! I think perhaps that question has no better ending than the infamous what cam do I use question!
Have that with mine also. Only real draw back to me if your doing body work the doors wont open and you have to move it around to do those areas. Really what your needs are. Right now it sucks with the Cuda on it ripped apart, no way I can take the doors off now until it is a roller again!Yeah. I like my two post for a lot of reasons but the biggest reason I would switch is simply due to stability of the vehicle while on the lift. I’ve got a 12k commercial rated one and little vehicles like my Jeep or the wife’s Durango are just fine, but man, I put the truck on there and no matter how much I try to center the weight, it’s still rocking pretty good. So I installed safety chains with booms to stop it
There is that too. Plus I’m getting too old with a bad knee to be kneeling on concrete setting the lift pads just so rightHave that with mine also. Only real draw back to me if your doing body work the doors wont open and you have to move it around to do those areas. Really what your needs are. Right now it sucks with the Cuda on it ripped apart, no way I can take the doors off now until it is a roller again!
They both have their place.And just to muddy the water, as someone with a two post I will never go back to a 4 post! I think perhaps that question has no better ending than the infamous what cam do I use question!
So what you’re say is.... buy one of eachThey both have their place.
I dont care for the 2 post,from a safety standpoint, balancing different vehicles can be a challenge. Setup was a pet peeve, crawling around trying to line up the ams in the right places.
Cant fix rockers,or safely strip a car down to the shell without adding supports.
4 post-
Front end work is a ***** on 4 post compared to a 2. Still do-able. Without jack trays or bridge jacks pulling wheels is near impossible.
They take up a lot of space.
4 post needs more maintenance and regular adjustments. Deck is dirty all the time.
Engine bay is 6-7 inches higher, working on a big wheel truck requires a good step in order to reach inside engine bay.
Pulling an engine is more difficult,the legs have to go under the hoist.
I can go on and on about disadvantages with both hoists,but i will use a 4 post before a 2 post any day.
Have been hoisting vehicles on 2 and 4 post for 20 plus years and i just feel safer using a drive on.
Fall is in the air up here this morning, down in 40s last night fog on the ground as a result. Fearless hound has already driven wife crazy chasing squirrels this morning. We may not even get a ripe tomato this year before first frost. Fargo still suks!
Better than snowIt is too early to be using that 4 letter word!!!! (Fall) We aren't finished with summer yet!
Why?Hmm John Dillinger to be exhumed from his grave
No reason given publicly. Just says county court gave the okWhy?
Fixed!Well... from the responses... looks like you are going to have to get 2 fireproof lifts...
