I heard some rumbles of thunder here but no rain yet.
We have only had a inch in the last month. Everything is brown................except the weeds. LOLWe had the same, but no rain. That's ok its rained a lot this summer, but that's kept the heat down. The humidity from all that rain is another story.
Me neitherDam house. Just went up on the small flat roof. Stupid idiots put shingles up there at some point and they are leaking. Hell have to call some one to fix it me and roofs don't work well!
hey, you might know this, any idea what size diameter brake lines the steel lines are on the mopars? 5/16? 3/16?Well I think (hope) I tracked down the last couple body bolts I needed for the Barracuda.
On that car is the hood latch and next to it is a secondary latch or emergency latch or a number of names people call it.
Anyway there someone before me used a couple aftermarket bolts. Hoppy had what I needed and a couple extra hood/bracket bolts for me.
I was looking for that someone with the coffee can of extra's and he was that person.
Thanks Ray!!
Yep after a buddy fell off the roof, broke his neck, and died a few years ago I'm not allowed on ladders or the roof without supervision.Dam house. Just went up on the small flat roof. Stupid idiots put shingles up there at some point and they are leaking. Hell have to call some one to fix it me and roofs don't work well!
I don't didn't have to go there yet.hey, you might know this, any idea what size diameter brake lines the steel lines are on the mopars? 5/16? 3/16?
Usually 3/16 sometimes the run to the rear can be 1/4 though.hey, you might know this, any idea what size diameter brake lines the steel lines are on the mopars? 5/16? 3/16?
cool cool, trying to get the brakes lined out on the polara tonight. thanksUsually 3/16 sometimes the run to the rear can be 1/4 though.
Get a roll of that easily bendable line make life much easier than straight steel sections.cool cool, trying to get the brakes lined out on the polara tonight. thanks
We live in the rust belt and most shops stock the green bendable stuff and a rack of fittings. I sold so many hydraulic flaring tools to those guys.Get a roll of that easily bendable line make life much easier than straight steel sections.
Take a tarp up and tack it down??Dam I am pissed off about that roof guy cant come till tomorrow when it is heavy rain forecasted!
yep!We live in the rust belt and most shops stock the green bendable stuff and a rack of fittings. I sold so many hydraulic flaring tools to those guys.
What direction do you lay them on a flat roof What section do you have flat? I assume it is actually a little bit of slope. Is it enough slope for roll roofing, or should it be a complete sealed membrane?Dam house. Just went up on the small flat roof. Stupid idiots put shingles up there at some point and they are leaking. Hell have to call some one to fix it me and roofs don't work well!
