greymouser7
Vagrant Vagabond “Veni Vidi Vici”
- Joined
- Apr 17, 2010
- Messages
- 3,745
- Reaction score
- 1,473
That page is old going off those prices
but interesting no lessThat page is old going off those prices
Definitely different. Why though?
I knew a girl that once.. Or maybe a few dozen times!He gave out!
Just got back meeting with a very interesting member had a great lunch. He is writing a book about the state militias in the rev war. Really interesting talk. Thanks again @gtx333
Why even run points? No condenser they will pit
I switched back to points on the polara. Thanks to a Hoppy tuned dizzy. why? because I could and I wanted to learn something new.Well, if the points only trigger the electronics they will run for a very long time, either with or without the capacitor. Then, if the points and condenser is there, and the ECU goes bad, it is an easy task to get the car running again. And no need for getting a new distributor. However, I see your point, it is a valid question. And I guess an electronic distr. would last even longer. But then, how will the advance be, will it be just like the one I have and fit the engine perfectly ?
Bill
The advance will be whatever Hoppy says it is! He is the dizzy wizard!Well, if the points only trigger the electronics they will run for a very long time, either with or without the capacitor. Then, if the points and condenser is there, and the ECU goes bad, it is an easy task to get the car running again. And no need for getting a new distributor. However, I see your point, it is a valid question. And I guess an electronic distr. would last even longer. But then, how will the advance be, will it be just like the one I have and fit the engine perfectly ?
Bill
some help maybeProb not the time to ask this but here we go
Any one know the lengths of oil pump drives?
Doubt you will get one off the shelf but easy to recurve even Craig could do it! Use the same springs and ask me for a cam with the same slots. Who knows what happens if you ask nicely!Well, if the points only trigger the electronics they will run for a very long time, either with or without the capacitor. Then, if the points and condenser is there, and the ECU goes bad, it is an easy task to get the car running again. And no need for getting a new distributor. However, I see your point, it is a valid question. And I guess an electronic distr. would last even longer. But then, how will the advance be, will it be just like the one I have and fit the engine perfectly ?
Bill
Wholy crap how many BB mopars are there?
How many miles a year you talking?If I went with a Mopar ECU, the only thing I would be looking for was the possibility for a high voltage coil and therefore a bigger spark plug gap. If I can not have a higher voltage and a bigger spark plug gap, I rather stay with points. The tune up of a gas engine is among my biggest pleasures in life. Ok ok, does not take much to please me, I know, rub it in if you want.
Bill
Back from the countertop shop, wife found stuff she liked so I'm happy.
Points last usually 10K. Get a supercoil and your done.
