LeRoy, average white boyIs it LeRoy? Or Le’ Roy?
it is? I never thought about it it's like William or Stephen to me..... just a name. Mom was French.Have to ask how did LeRoy come about? Different name.
Average? You think rather highly of yourself!LeRoy, average white boy
That's a new one on me Bill. I have no idea how that will work. Pretty sure the five pin is early electronic 711/2 72?
I see......Average? You think rather highly of yourself!
I see......
You are talking about the magnetic trigger device. That is not the same as ignition points...I have been searching on my phone, can not find it. But if you think about it, there is a tiny little coil in the electronic distributor and the rotor passes it, it creates a signal. A plus and a minus that goes through the two wires to the ECU box. Now, if you manage to find out which of the two wires to connect via a resistor to the car battery, and then connect the other side to the points, you will have exactly the same signal to the ECU.
Bill
Why?I have been searching on my phone, can not find it. But if you think about it, there is a tiny little coil in the electronic distributor and the rotor passes it, it creates a signal. A plus and a minus that goes through the two wires to the ECU box. Now, if you manage to find out which of the two wires to connect via a resistor to the car battery, and then connect the other side to the points, you will have exactly the same signal to the ECU.
Bill
Ha,. LeRoy is very common around the DC Baltimore region.........
SundayWhen you leaving Mitch?
I cant figure out why you keep coming back. Son if I had a hot number like that waiting on me in Thailand and was in your shoes. 10-4 over and out,Sunday
He misses hamburgers!
bILL REALLY INTERESTED IN SEEIN THEAT. tHE ECU IS JUST A SIGNAL AMPLIFIER BASICALLY. when THE RELUCTOR PASSES THE PICK UP A SMALL AC SIGNAL IS GENERATED THE ECU AMPLIFIES IT AND SENDS IT TO THE COIL.
Good morning everybody, and everyone else who feel left out from the everybody.
Anyway, my question about the tail lights. I guess it was a minimal explanation. What I meant was, miy tail light bezels are pitted. I have seen worse, but I can not believe they would look good after re chroming. So, my question was, can the pittiing be repaired. I remember reading about it, maybe like 20 plus years ago and I think it said someone drilled in the pit hole, and filled metal in it. But this metal, can it be repaired at all filling metal in. Can it be soldered for example ?
Bill
Ouch $. I know they ain't cheep, but never saw a price. Generally I heard if they aren't rare, they aren't worth doing though. I don't think solder wills stick to the pot metal. Don't know what they use for filler. The ones for my Duster are repopped for $400+ for the pair. I found nice used ones. Bought several tail lights and put together all the best parts. Then sold everything I had left from them at Carlisle. Probably ended up with less than $100 in the 2 lights I kept.Pitted pot metal can be repaired and rechromed. I bet your 4 taillights would cost $2000 or more to do.
