First cup here!
Makes sense, as distributor isnt intended to be grounded. The clamp isnt good enough. A ground strap would work.One thing I have ran into helping guys out the distrib has to have a good ground, the OEM pick up does not need one but the HEI has to have one or you will fry the modules out . Just FYI I recommend a metal dual point crush gasket to do it easily.
Points are grounded or they will kind of rotate around the firing order if not. A pick up no is not grounded.Makes sense, as distributor isnt intended to be grounded. The clamp isnt good enough. A ground strap would work.
PIA unless you have a Bridgeport to cut the potting out and are able to save the connector.Thought about that too. I have a thread bookmarked that the guy did that.
On the pt cruisers,there is a ground strap from strut to body,aparrently to dissipate static and prevent premature strut bearing failure.Wonder if that would eventually electronically wear the shaft out if the shaft is grounded and the case is not? Prob overthinking it to much.
I dont have a Bridgport but I do have a flatbed mill.PIA unless you have a Bridgeport to cut the potting out and are able to save the connector.
Let me know when I have some fun stuff laying around. Just that distrib I sent you should wake it up.I guess I'm getting ahead of myself, I have another week to go. I have to re-ring the engine, bought the ball hone this morning. Got to wait for the oil pan to get powdercoated then I can think about the ignition.
That and a two flutte end mill will do it then!I dont have a Bridgport but I do have a flatbed mill.
