Stop in for a cup of coffee
Foundation footprint on my house is 24'x48' with 24'x36' being 2 story house on a 120'x60' lot
Mines about that in a rancher. Full basement. Plus garage I think is 20x20. If not full of clutter, shelves, work tables etc. It would probably be a good size to work on a car. It's a 16ft wd door and considered a 2 car garage- not likely to ever see 2 cars.
If you were to build a 1 car work space, due to limited space. What size would you make it so it would fit at least a B body and still have room to work around the front and sides?
Take the dimensions of the body and add 6’ in every direction.
That makes it 20’ wide and 30’ long.
Minimum would be 16’ x 24’...and I do mean minimum.
Our Christmas lights are up and running...
The temps in the garage are starting to level out. Only a 3* difference from on the concrete floor to 6’ up, dead center in the space.
I am really liking this new window insulation!
should be the same
Was outside now in the dark adjusting the engine after I put the pcv valve in, and I can not get it to slow down enough. Too fast idle in other words. Probably 800 rpm or so, maybe a little over too. Without the pcv valve I could adjust it plenty down.
Bill
Bill
vacuum leak? timing?
More air into the carb and now the timing and idle mixture probably need adjusting. It’s likely running lean.
I am starting to get a bad feeling I missed something in the dark with only the little flashlight.
And tomorrow it is supposed to rain between 1 and 2 inches... So who knows when I get out there again.
Bill
@Mattax you have the first batch of lite roast Huehue I have done. Most people ask for the Antigua in lite. Will have to tell me how it came out.
Another day or two. Let me get the hang of the grinding and quantity to where I like it.
I *think* Keith served Huehue. Was that also med dark? That was really good.
how do I get in on the coffee of the month club? :lol:
The Hue-Hue is a bit bolder and I would say what I had was also a bit darker roast. I knew you were asking about light roast, so figured you would like the Antigua better.
