I like big butts and I can not lie!
I prefer small butts...
Dug this heavy thing out of the shed, going to put it in safer place but this made me think slant again.
I think there is a flange that bolts to the top of that.Interesting bolt pattern on that carb flange
One size fits all?
This has never been on an engine before so it's going to get interesting
That it's why I will be miss 4 speed for life, 4 speeds sound so awesome.One good thing about it. With the 4gear none of the kickdown linkage monkey motion to deal with View attachment 1715448346
I could dream all day about that addicting low RPM whine from the four speed and how it sounds when you get off the clutch and get going.
The sound when you change gears and second you hear the compression from the engine unloading with the clutch in.
A 4 speed makes driving so fun.
I'm only building a few automatic cars just because I have enough cars to have a little variety that plus I could go broke buying 4 speed parts all day.
When I did the 289~~~>351W swap in my Ranchero I put a C4 behind the 351. It was alright. Found the right linkages at the junk yard made it easy. But just not the same hot rod to drive. Didn't take me long to find the flywheel to go back to the 4 speed that lived happily behind that 289 before the switch.
This tractor sounds exactly like my old duster used to.
When I hear this then I get back into v8s
Yea, for me 4 speeds make a muscle car a true muscle car even if I need pedal extenders.
A piece of 2x4 duct taped to the pedal really makes all the difference.
You can weld and you used duct tape on your pedals? Oy Vey girl!
The sound when you change gears and the second you hear the compression from the engine unloading with the clutch in.
I beg to pardon Sir...But those are Wheel Covers...... @Rainy Day Auto
My wife is 3.5 years older than I am.I like older women!
Wheels back under it. Decided already to put the springs i removed back in. Or one for sure. View attachment 1715448391
No. Just cleaned up the old ones.Newly manufactured front hangers?
Leaf spring eyes are down instead of up, instant 2” drop.
Took 3 shortest leaf springs out is another 1”,and with sag probably 1” more. I am going to run out of travel.
