Stop in for a cup of coffee
Im on the 3 set of cats on this car. First set went to certify another mustang at the dealer my brother worked at. Second set all that was left was the housing and a little of the ceramic dust in one of the mufflers. This set and I am sure the driver side one is doing the same.
I am trying to get something else up and reliable so I'm not stuck. Replaced intake last time I was home.
Car hasnt been the same after the electric fan went out for the second time a little over a year ago. Blew both head gaskets so it has totally redone heads gaskets intake egr tubes shocks struts, gears and bearings (timken) in the rear, about the only think not new is wiring, tranny related stuff, injectors and 7 coils.
All the blinking check engine light means on an OBDII car is that the fault is actively happening RIGHT NOW.
Do you have emissions testing in your area?
No I have to install my mil eliminators for the rear o2 sensors.
Put the Dorman intake on and it moved my power curve at least 300 rpm maybe a little more. Runners are shorter. Wish I knew that before I bought and installed it. Found out it was shorter runner when I tried to put the old one in the box the new one came in.
You can do it for them all. If that's what you want to do. Do you have eliminators yet? You actually don't need them.
I have a set for the rears. Ran them when the old cats were blown out. Problem is if someone knows what to look/smell for they can tell if you have cats so I replaced them.
@FISHYPETE done
Wonder how long it is before Iran blames us for the civilian lane crash, hell of a coincidence.
Rumor has it, Iran itself may have accidentally shot it down. Water buffalo rumors of course but they did have their ADA fully activated after they launched those missiles
Apparently Boeing and French investigators asked for the Flight data recorders already and Iran told them no. In past crashes, Iran has turned them over. Awfully suspicious there
Hey anyone ever add a steering stabilizer on a dodge truck? Still have the shimmy when driving, cant figure it out all the parts are good also.
Good morning to Coffee Land.....hope all is well.
I have added them to Jeeps with Lift and Larger tires. Did the job. Also sold many universal kits, while in the Parts Business....
any preference? She used the truck yesterday and drove her nuts. Me I am used to the W150 death wobble!
