Really, any one of them is ok, as long as its not a cheapo. We used to sell Monroe or Gabriel. Check Rock Auto maybe...any preference? She used the truck yesterday and drove her nuts. Me I am used to the W150 death wobble!
Yes I have, it solved my death wobble.Hey anyone ever add a steering stabilizer on a dodge truck? Still have the shimmy when driving, cant figure it out all the parts are good also.
Thanks. Figured it would. I also have pretty good bumpy off road tires on it I am sure that is part of it also.Yes I have, it solved my death wobble.
yes. but I used the dual Rancho kit. I'm about to do the same thing on my jeep, even though it has one as I'm having the same exact problem despite all new tie rods, track bars, ball joints, hub and rotor. Only thing leftHey anyone ever add a steering stabilizer on a dodge truck? Still have the shimmy when driving, cant figure it out all the parts are good also.
that aint bad!Hey Ray, only 25 bucks for our grinders......So far!!!
hey, did you see the post about my 383? its a 70Hey Ray, only 25 bucks for our grinders......So far!!!
I saw. Need a 66. For satellite....Might not need one, mine might be ok, freeze plug missing, wont hold water, so engine not pressure checked for cracks...hey, did you see the post about my 383? its a 70
Good morning Craig. And Cheryl. Dang just over 200 Days till Carlisle..Hey Tim whats shaking?? Oh no not that, how you doing?? There that's better.
My Scout was horrible! Leaf spring suspension with shackles in the front. Did a reverse shackle on it so the axle pushes rearward instead of forward when the spring compresses. Now if I can get off my *** and finsh the beast so I can see how much difference it makes..Yes I have, it solved my death wobble.
EFI.....Sooo Question for the brain trust that is the coffee shop....
My 408, coming soon, in my 66 Dart, Carb.d or EFI? What do you guys think ?
Won't make the car boring to drive?EFI.....
One thing my daily driver doesn't have .....a computer or a check engine lightGot to run the car over to the dealer and see if they can pull codes on the DD. I plug my tuner in and is says no codes but the service engine soon light justs keeps on blinking. Normally just stays on if it has a code.
i figured. I just wanted to make sure you saw i did checkI saw. Need a 66. For satellite....Might not need one, mine might be ok, freeze plug missing, wont hold water, so engine not pressure checked for cracks...
