Not sure if this is going to live even after a getting dingle balled real good.
That was my thought too, but I like a puzzle to be a challenge!Dang, that would be a tough one.
DAM tp SHORTAGES!Not sure if this is going to live even after a getting dingle balled real good.
Make sure the nipple gasket is good also, have to be pretty tight sometimes.
That's a big thing I learned from MN folks, you always get outdoors. And have fun. I gotta take a break from all the gloom. People aren't making sense around here...you'd think rich people would be smarter! Yep "hanging around" I wanted to see if I could still get myself up on the monkey bars at 60, it is way harder than when we were kids! Took several tries but I did it and went back and did it again.
The 74 duster is totally cuteI put this one together this afternoon to use as a jigsaw puzzle image. I think it would work...
You should know I don’t back read haha
Very easy to start. A $50 kit get's you started. The plastic bottles and even the caps can be reused as well as the cool fermentation keg. Refill kits are as cheap as $20 that makes 2 gallons.
American Lager Complete Beer Making Kit
Yea. I know what you mean.
Happens every time I hit a light pole. What a PIA.
I hate when that happens!
Sure. hold still.Too bad I don't like beer... Do they have whiskey kits????
I took off a blue permatorque gasketThat looks like a head gasket failure...
Put a straight edge on the head and block surfaces and check for warpage...
You can use a fel pro head gasket for a better seal... But check the surfaces are straight first... Then have any of them milled to get them back...
Lol. Forgot that one...Got the 05 mustang running today.
Turned out to be the inertia switch in the trunk.
That was an easy fix.
That's horrible! Almost as bad a a Virus!I need to tear down a 351 engine tomorrow
Dont worry, Ray! its just to Separate the scrap aluminum from the steel/cast iron.That's horrible! Almost as bad a a Virus!
Is there an actual build thread for this pick me up??September flashbackView attachment 1715491744
Yup, but its all in my head..Is there an actual build thread for this pick me up??
