Stop in for a cup of coffee
Morning Hurst shifters. A balmy 15 degrees F here again this fine morning. I solved a very difficult problem yesterday on my integration issues for EFI with regard to the tach. Raisin pie to the tech dept at Dakota Digital. They have a BIM patch cord for exactly that issue with Holley. Problem solved! Happy little guy right here.
Thanks, for a reminder. I've got one of their units in the 55. When I swapped out the battery I lost all my settings. I need to call or look online and see where the reset button is.
Thanks I've got one of there units in the 55. When I swapped out the battery I lost all my settings. I need to call or look online and see where the reset button is.
They have a easy system, and they let you talk to an actual person for tech questions. They have a pretty good FAQ on website. You might take a look. I can check my paperwork and see if they mention that.
How can they say that there will be an end to the stay at home mandate when there were 2405 corona virus deaths yesterday???
I'll look. Mine was installed probably 10 years ago. I took a quick look and didn't see anything simple like a button or switch. Like you said, it's something simple.
I'm pretty sure it won't come to an end.
It will get a new name and a return to normal if we can call it that will be phased in.
The phase in will be closely monitored and progress based on the case level.
This phased return will last for months.
It will get a new name and a return to normal if we can call it that will be phased in in certain parts of the country to begin.
SoCal distancing....
We'll all pretend that we are in southern California....
Son was running his truck in driveway, locked up.i figure due to too much gas in the oil.
Previous owner couldnt get it running,so lots of gas down the carb. distributor was 180 out.
and with one pipe plugged, would have added more.
and nothing on dash was working, he was running it with distributor jumped to battery.
Well not sure what they are doing. They did report though with the 7K who have died in NYC, all but a few hundred victims had an underlying condition prior to entering the hospital. Unfortunately, I think that's a huge factor with this virus.
Good Morning All! I woke up with a 99.4 degree temp this morning, that's two degrees higher than what I've been seeing. Frickin thermometer is flaking out too, fading, think battery is low. Gotta figure out what I'm going to do. Took acetaminophen, went back to bed for an hour, went to 99.5. Hmmm
The tornado from where it touched down till it headed into the marsh
