90% sure I have a burned valve on no 4 cyl on the 440. Cant get a leak down tester into the plug hole just to tight to the inner fender with the try y headers. Seriously thinking 440 source heads.
Look into the Marsh Performance sidewinder Big Block head. They were what I planned on going with until the deal with Mopar tim came up. Marsh knows his stuff and his heads, even for Chinese castings, have rave reviews and he personally assembles each head himself and warranties it. Will build it for your combo for about the same as OOTB 440 Source heads
Stealth heads are not made in USA... castings are Chinese. Valve springs are also Chinese sourced. Only thing on those heads that are USA made are the valve locks and seats that they get from COMP CamsLooked at them want made in USA stuff only.
Mondays are my Saturdays, catering to my wife on Saturday and Sunday, Monday I'm my day . Good morning FrankAaannnd first!
Figured i was out working late yesterday,i would sleep later.
Cruze for a crank seal, then brakes on the impala.
Will probably work saturdays for the summer, take mondays off.
If you don’t have to have aluminum and are putting them on an otherwise stock 440. You might look at Indy Cylinder heads. They were selling factory heads, ported, lightly polished, with larger valves and better springs for 600 a pair.Hmm let me shoot them a pm. Friend has them on his Belvederere and really likes them. Look cool also! Be lucky to do a set of heads for that price if one of mine is cracked.
Marine engine rated 500 in the boat. Basically 10.5 pistons, ported 906 heads a Lunati cam and gear drive.If you don’t have to have aluminum and are putting them on an otherwise stock 440. You might look at Indy Cylinder heads. They were selling factory heads, ported, lightly polished, with larger valves and better springs for 600 a pair.
To be frank, I’ve been debating selling my Edelbrock heads I got from Tim and having marsh build be a set of his ported and polished.They are attractive I like they match the springs to the cam, which is large.
yeah, im curious what the full port price is. I may call Monday.Basic 895 is attractive.
have the cam card still?I want to get my cam specs and send it to them and get a price.
sweet. if its the one in the link, its fairly mild. shouldn't take much extra to make any heads work with itOf course.
