Stop in for a cup of coffee
It turned out that we had a shingle on the living room room that was half ripped out. It folded under on the one edge and must have diverted the water against the wall to the higher roof forcing it under the edge. It was exactly above the ceiling leak.
I got my general repair guy to stop by and fix the shingle back in place and caulk the seam along the wall edge. We are supposed to get more storms tonight so I guess I will find out if it is really fixed.
Glad to see you are mostly unscathed Dd. :thumbsup:
Thanks. All night I kept thinking what the damage outside might be. I was relieved when it was that little. We will see how tonight’s storm ride goes...
You have power?
Got the Neon In the garage and up on ramps earlier. Dropping the tank looks easy enough. Not sure how I will drain it though. I think it’s a little under half full, 5-7gallons Chiltons says there is a drain, but not seeing it. Maybe a drill pump with a piece of tubing down the filler...
Sometimes there is a standpipe with a cap on it.
Troubleshooting the convertible top no power issue. There is a bigass relay/continous duty solenoid on fender. It wont power up, and i cant find what triggers it. Dammit. 1/2 the dash apart, and the electrical is a mess. Lots of jiggery pokery in this one.
Ok. So here's where I went. Decided to open a window.
It had a snap ring and washer, and just an o ring. Lucky me I have an o ring assortment, and I have the right one. O ring in arm re attached, and closed up the hole. Never know if I'll need to get back in there.
You have power?
Yep, we never lost it but the lights flickered a lot and I thought it might go out. They did a bunch of automatic reset breaker retrofitting on the lines around here that quickly isolates the damaged area and restores the power for the other parts that just tripped initially. We used to have to wait hours for them to trace the lines and reset the breakers manually.
This neighborhood used to be all woods before they cleared it to build the houses. Because it was old woods, it was filled with ants. Since moving in, I have slowly been eradicating the colonies around the house. I thought I had cleared them all out, but I’ve been seeing a lot of ants down by the end of the driveway. I have been hunting for the anthills since last Summer so I could take them out. I have never found any but today I decided to flip over some of the big rocks in the ornamental rock pile down there.
Yep, found them!
I will let them settle down and then feed them some of this stuff. 1/4 tsp and they will carry it in and feed it to the colony and the queen, wiping them all out.
So solenoid that gets some sort of switched power is a dead short. Tracing it through firewall with my power probe circuit tracer, i see its pinched between heater housing and cowl. Looks like it has a couple places pinched/shorted.
Owner asks when he bought it, power top works? Yup,NOPE!
I managed to get it open, and folded into trunk, but it has several deficiencies in order to operate. Lots of wiring to sort out.
Gotta git a new one of them..
Happened on the way to the office this morning.
That tire is not that old and I never expected this to happen today. Made me late and then I was behind all day from having to change a tire lol.
The wheels on the car go ‘round and ‘round
‘round and rou...POP!
Flappida, flappida flappida...crap.
People should see someone changing a tire and let them work.
People stopping to help actually slowed me down.
I have a routine and had to stop and talk and explain my plan and bs for awhile.
However I do appreciate the gesture so I don't want to sound like an ingrate.
This is the NWS report on the weather we had yesterday.
INFORMATION ON JUNE 3, 2020 DERECHO...
A DERECHO, DEFINED AS A LONG-LIVED AND EXPANSIVE THUNDERSTORM WIND
COMPLEX THAT PRODUCES WIDESPREAD SWATHS OF DAMAGING AND OFTEN
SIGNIFICANT WIND GUSTS OVER A PATH GREATER THAN 240 MILES IN LENGTH,
DEVELOPED JUST SOUTHEAST OF LAKE ERIE DURING THE EARLY MORNING HOURS
OF JUNE 3, 2020.
DAMAGING WINDS IN EXCESS OF 60 MPH WERE SPORADIC
IN WESTERN AND CENTRAL PENNSYLVANIA, BUT AS THE THUNDERSTORM COMPLEX
MOVED INTO INCREASINGLY UNSTABLE AIR IN THE EASTERN PART OF THE
STATE, WIND DAMAGE REPORTS BECAME MORE NUMEROUS AND
WIDESPREAD AND OVER 250 WIND DAMAGE REPORTS WERE RECEIVED BY THIS OFFICE FROM
EMERGENCY MANAGERS, TRAINED SKYWARN SPOTTERS, AND THE GENERAL
PUBLIC.
MOST OF THESE REPORTS WERE LOCATED WITHIN A 50-MILE WIDE
SWATH EXTENDING FROM BERKS COUNTY EASTWARD TO THE PHILADELPHIA METRO
AREA, THEN FURTHER EAST TO THE OCEAN COUNTY SHORELINE IN NEW JERSEY.
WIND GUST REPORTS BETWEEN 60 AND 70 MPH WERE COMMON, WITH SOME OF
THE HIGHEST GUSTS AS FOLLOWS:
93 MPH AT BEACH HAVEN, NJ (OCEAN COUNTY),
92 MPH AT SURF CITY, NJ (OCEAN COUNTY),
83 MPH AT READING REGIONAL AIRPORT, PA (BERKS COUNTY),
76 MPH IN POTTSTOWN, PA (MONTGOMERY COUNTY),
AND 76 MPH IN BRIELLE, NJ (MONMOUTH COUNTY).
IN ADDITION TO DESTRUCTIVE WIND GUSTS, FREQUENT TO CONTINUOUS LIGHTNING, HAIL AND HEAVY DOWNPOURS WERE ALSO EXPERIENCED THROUGHOUT THE AREA.
TRAGICALLY, FOUR DEATHS WERE REPORTED IN THE NWS MOUNT HOLLY AREA OF
RESPONSIBILITY FROM THIS DERECHO. THREE FATALITIES IN MONTGOMERY
COUNTY WERE DUE DIRECTLY TO FALLING TREES, WITH THE FOURTH FATALITY
IN DELAWARE COUNTY DUE TO A HOUSE FIRE CAUSED BY AN ELECTRICAL
MALFUNCTION FROM A FALLEN TREE.
THIS IS THE HIGHEST NUMBER OF FATALITIES FROM A DERECHO EVENT IN THE AREA SINCE 1950.
BECAUSE THIS DERECHO MOVED OFF THE COAST EARLY ENOUGH IN THE DAY, THE WARM
AFTERNOON SUN WAS ABLE TO SUFFICIENTLY DESTABILIZE THE ATMOSPHERE
FOR THE FORMATION OF ANOTHER ROUND OF SEVERE THUNDERSTORMS OVER
SOME OF THE SAME AREAS WHICH EXPERIENCED THEM EARLIER IN THE DAY.
REPORTED WIND GUSTS ASSOCIATED WITH THESE LATER THUNDERSTORMS GENERALLY
RANGED BETWEEN 45 AND 65 MPH, WITH A 68 MPH WIND GUST MEASURED AT
THE PHILADELPHIA INTERNATIONAL AIRPORT AND HIGHER GUSTS REPORTED IN DELAWARE COUNTY.
THE REMAINING THUNDERSTORMS THEN MOVED OUT OF THE AREA BY 1000 PM, WHICH BROUGHT AN END TO THE DAY’S SEVERE WEATHER.
OF JUNE 3, 2020.
PUBLIC.
Here we go again...Just started raining and sounds a bit ugly outside right now.
We lost Xfinity till 2pm today. Came back up as I was leaving for work. Others nearby lost power all night, so not complaining too much...
