Cook temp? internal meat temp? Wrapped with foil or not?
Oops.Someone refastened the heat shield on a car,with drill tap screws. To the gas tank!! I had my fun replacing that fuel pump.
Mmmm - fan belt. Does that pair better with gasoline or antifreeze?Not brisket. It will be as tough as a fan belt if you try to eat it now.
Either is good...just need to slice it thin across the grain. Tastes best with DOT 3 brake fluid. Gives it that sweet tangy flavor...Mmmm - fan belt. Does that pair better with gasoline or antifreeze?
If you cut into it to check it... its not done. It's done when it pulls apart with 2 forks.The grill surface thermometer said 250 degrees, the grill hood temp said 275 degrees. I think I should be careful where I put the grill surface because it's indirect heat cooking and I placed it too close to the active burner. Maybe should have placed it halfway down the brisket, then would have realized cook temp was low. Placed brisket in the oven at 230 degrees, wrapped. BTW I had the meat thermometer poking out of the foil, placed into the thickest part of the brisket.
You should be good.The grill surface thermometer said 250 degrees, the grill hood temp said 275 degrees. I think I should be careful where I put the grill surface because it's indirect heat cooking and I placed it too close to the active burner. Maybe should have placed it halfway down the brisket, then would have realized cook temp was low. Placed brisket in the oven at 230 degrees, wrapped. BTW I had the meat thermometer poking out of the foil, placed into the thickest part of the brisket.
Epoxy, o ring and same screw, but left the heat shield off.Oops.
Any good way to fix holes in these plastic tanks? Or did you replace it?
Not off the car, jus not screwed into the tank.Epoxy, o ring and same screw, but left the heat shield off.
HeyGood Evening all..............
How are you the Ray of Hope??Morning! Its Monday right?
Ray of Hope? Oh good grief, I am having a nightmare. I need to wake up
