Unconventional
Salt give concrete that "exposed aggregate" look Very stylish in some circles
Yep.And cars as well
Interesting!Concrete contractor I dealt with, when he needed to do an exposed aggregate slab, he used Pepsi and water. I had the extra rocky mix which he would lay and finish just like normal. When the concrete got to the point when you wouldn't leave tracks when you walked on it he sprayed the slab with his Pepsi and water solution. Next day just wash the fines off the top of the slab with a water hose leaving the rock exposed The sugar retards the set of the concrete on the surface.
Was a cold morning. Decided to fire up pellet stove. So outside work is off until about now. Decided to start picking away at wiring.instead of buying sockets i opted to go pull the light harness out of a parts truck. Just cleaning it up and pulling unnecessary wires out. This will suit my need just fine.
Been outside grading for some more concrete.........................
It is hard work, but when completed it will be worth it.....Cement is forever......
Yep, get yourself a pack of 'Bama J's.... View attachment 1715609987
Cut CutNo stems no seeds that you don't neeeeed
Acapulco Gold is ......... baddaasss weeeeed
Don't forget the Doritos man. I got the munchies man!Whose got the Twinkies?
I think they should legalize the stuff and pass out freebies to the protesters to keep the destruction and looting down. Mellow them out a little bit! Did you ever hear of that going on when the Indians sat around smoking a peace pipe? They weren't smoking Prince Albert in those!
hey blind baby.....Cut Cut
Uh ya!hey blind baby.....
