I will treat it better then the last guy.
That’s really not hard to doI will treat it better then the last guy.
Speaking of the new house another decision was made.
Yes, there will be new cabinets in the kitchen.
Yes, the old cabinets will be used between the two garages and the basement shop.
I found out one of my buddies has already spoken to Cheryl about buying the old cabinets...really he knows better which is why he didn't ask me.
A wintery mix predicted for Monday. (I call B/S) I expect the weather folks to be wrong like they usually are. LOL
Well so far 3 of the bodies recovered from Seacor Power were friends of mine. Not looking good at this point with the amount of time that has passed.
I figured you knew bunch still on it. Sorry to hear this..Well so far 3 of the bodies recovered from Seacor Power were friends of mine. Not looking good at this point with the amount of time that has passed.
What primer did you use?Buffing and waxing Dart today. If I had paid what Mitch did for paint, I would not be real happy. BUT I did not, and I an very satisfied with results.
LOL Wait for it..................................What primer did you use?
Really? The stuff I’m looking at is from Eastwood.For real. thinned and sprayed.....Sanded nice, heavy fill......AND Cheap.....
Gallon enough?For real. thinned and sprayed.....Sanded nice, heavy fill......AND Cheap.....
Isn't that oil based?
It is......Isn't that oil based?
So it can’t be used with urethane paints right?It is......
Should be......Use a inexpensive gun, a HF gun works great....for this primer....Gallon enough?
I did not investigate, I was spraying lacquer....So it can’t be used with urethane paints right?
