That's really good primer. Shame they don't have your green in a gloss finish. Although some places will custom mix it.
ewwwww lolNothing screams mid-life crisis like a goatee and nipple rings...
I'm kidding, I don't have a goatee...
I think for me, I’ll just try to match everything to be the same base type. Being a rookie and allGenerally all synthetic /alkyd enamels will be fine, once fully cured 2 to 3 weeks is my guideline.
Oil based primers can be cut with urethane grade reducer too or xylene and acetone.
Many I know will use rusty metal primer, followed by fillers and urethane primer surfacers on top.
When in doubt test a small area, if primer ain't fully cured or solvents too aggressive can and will bubble.
Good luck
I’m thinking of going with gasser greenThat's really good primer. Shame they don't have your green in a gloss finish. Although some places will custom mix it.
Looks like Gas Monkey green...
Gas monkey green?Looks like Gas Monkey green...
Best one I ever saw it was a tribute to the original owner..Finally got gas pedal in buddy’s truck. Now woking on seat pedestal.
Says he wants to build a steering wheel. This should be interesting. I think we can use his original,and knock the plastic off, and build a wood ring. Could be fun.
You might be going right past me if you going down I-70. I'm in Topeka.Getting ready for my first cup of coffee ever in the state of Kansas. Then off for pancakes with Leadfoot and '73red-duster. 1450 miles to get from home to Dodge City Kansas.
I’m sure it turned out fineWell, all buffed. Not perfect but it was painted outdoors......
It did....I’m sure it turned out fine
I wasnt but used to ride that boat.Bummer, I heard that story in the news either yesterday or day before, was hoping you weren't on it.
adding a stripe, just a really wide one...Spray the whole thing red, then the white....
Dont do much in the evening, but my buddy Ron came over with his cousin Erv. I brought my wood lathe in and Erv made a pastry rolling pin.he likey woodworking. Good at it tooYo Frank, what's on the agenda for the day ?
Morning mitchGood Morning Moparians !!!!
If you spray the red first, use a bleeder sealer or your white will turn pink. Less masking if you do the white first.@Mopar Tim maybe you’ll know this, if I wanted to duplicate this paint job on my truck, would I spray the white first, then tape it off and spray the red?
