HMM, Nothing????Hg on. What is it doing
So it won’t turn, won’t drive, won’t raise the loader?HMM, Nothing????
From what I heard, it moves, just the accessories are inop....So it won’t turn, won’t drive, won’t raise the loader?
If it moves and turns and the brakes works, then not likely the pump. most likely water got in and is blocking an internal screen. Had this happen more than once. Especially if left outside in a heavy rain. Changing filters likely won’t help. John Deere not only uses filters, but they use prescreens through the system. In seemingly random places depending on model. One or more clogs and the system goes down. Everyone forgets about the screens. Dealer will claim no screens but I’ve yet to see one without them.From what I heard, it moves, just the accessories are inop....
or notFrom what I heard, it moves, just the accessories are inop....
Emulsified..Oil and water under pressure....Wasn't there something about the Hyd oil being all milky?
A the hydraulics failed on the tractor yesterday, checked the level it is all milky like water contaminated, no idea how any got in there. Change it and the filters today and keep my fingers crossed. Of course the bucket and deck are down so have to drag it around. Danny thought she broke it mowing!
Oh boy. Yeah water definitely in then. Which means lots of air bubbles tooWasn't there something about the Hyd oil being all milky?
Yep not goodEmulsified..Oil and water under pressure....
Tire.com/sizeThere must be a Tire search that uses diameter, width, type parameters. Every one I find so far wants to know what you want to put it on and only shows what fits the OE wheels
You can also go here and this lists tires found everywhere onlineThere must be a Tire search that uses diameter, width, type parameters. Every one I find so far wants to know what you want to put it on and only shows what fits the OE wheels
What I have used....^^^
If I had not spent so much on restored KH brakes, I would have changed to large pattern. then 17 inch wheels, these...Contemplating a different look for the Black Express and I don't find any 20" wheels that fulfill the desired look. I think 17s are the smallest that will fit over the brakes.
Or these? Heheheheh....If I had not spent so much on restored KH brakes, I would have changed to large pattern. then 17 inch wheels, these...
I have those!!! 14 inch Small bolt ....
