It also rhymes with d.... Be careful out there.Bricks rhymes with chicks...
My dog don’t move that much. lolIt doesn't count when you attach the phone to the dog and let him run around...
Your right, it's a code word. We all know that old fart ain't laying bricks...probably laying something else.Bricks rhymes with chicks...
Pete sounds like a busy morning!!Good morning, two of our 5yr old granddaughters had a sleepover, they want cheeshey eggs for breakfast, then go to the playground park, go for a side-by-side ride , and......?
That was I Krazykuda , My problem was slow turn signal only on one side the other side was fine . Problem was in the running light wiring . Thanks .I know somebody had slow turn signals on here in the past few days and found a wiring issue, but I can't find the posts...
This guy may be able to use your remedy...
Sloooooow turn signals
Bummer...........Dam tractor is fucked think it is the hyd pump but need a few special tools to check it I guess off to have it towed to JD tomorrow!$$$$$$ Small mower not a cabel to be found locally, E bay to the rescue! This just sucks!
Good on you. I get broken stuff here all the time. Usually a new carb fixes them. Or a pull rope.....Just the cloud was over head yesterday. Took the truck for a hit down the block. Scary fast! Not even tuned yet either!
not today. Every two weeks. Trying to save money...Pasture Pool today?
not today. Every two weeks. Trying to save money...for Coors gold!
Cool............
Hg on. What is it doingDam tractor is fucked think it is the hyd pump but need a few special tools to check it I guess off to have it towed to JD tomorrow!$$$$$$ Small mower not a cabel to be found locally, E bay to the rescue! This just sucks!
Also, you don’t “need” special tools to check a John Deere Hydraulic system. Before you do anything with the dealer/service center, let’s see if I can help walk ya thru checking it the poor mans wayDam tractor is fucked think it is the hyd pump but need a few special tools to check it I guess off to have it towed to JD tomorrow!$$$$$$ Small mower not a cabel to be found locally, E bay to the rescue! This just sucks!
