Another Party at my house tonight. Was fun. They always try to outdrink me. Who wants to eat Octopus ????LOL..
View attachment 1715745659 View attachment 1715745660 View attachment 1715745661
Olive oil, garlic powder, on the grill.
It is coated, and I will put something over the repair. Trying to figure out what to use. Didn’t see anything at Home Depot that was actually for that.
Also get a call from one of the in laws. They are at the supermarket and they had 40 LBS of quartered chicken for $10!!!!!! No crap I bought one. I got 36 quarters in the box! Holy crap just fit in the freezer. Guess we will be eating a bunch of chicken!!
That was the same situation at my mom's house, except it was Channel not HD at that time.
I used some sort of cement type wall seal product. Dry-lock might have been the name?
The drylock I have used is for inside the walls. Thats the only one I saw at HDThey have dry loc
I saw a bunch of Henry stuff for roofing. Not sure if that is good under ground. So many of these product have become water based, I’m leery of using them for something like this. Will run down to Ace in the morning. If I don't find anything made for it, I will get neoprene caulk and smear it on...Henry's Wet or Dry patching material should serve that function. Shouldn't it?
Yep Didn't see anything to indicate that it wouldnt work just as well outside. And of course that was more important (and I didn't have time to really hunt for stuff).The drylock I have used is for inside the walls.
Well... just looking to do a patch. The walls were coated black. So I will find something similar.1996 BOCA
If there is no hydrostatic pressure expected
1813.3 Damp proofing required
1813.3.2 Walls: ....All holes and recess from removal of form ties to be filled with bituminous material or other approved methods or materials. Unit masonry walls shall be parged on the exterior surface below ground level with not less than 3/8 inch of portland cement.
1813.3.2.2. Wall Damproofing materials: Dampproofing shall consist of bituminous material, 3 pounds per square yard of acrylic modified cement, 1/8 inch of surface bonding mortar complying with ASTM C887 listed in Chapter 35, any of te materials for waterproofing listed in section 1813. 4.2.2, or other approved materials...
Where there is expected possible hydrostatic pressure
1813.4 Waterproofing required
1813.4.22 Wall waterproofing materials: .....two ply hot mopped felts, not less than 6 mil (.006 ") PVC, 40 mil (.040") polymer modified asphalt, 6 mil polyethylene or other approved methods of bridging non-structural gaps.
My takaway from all that codespeak is either some sort of 3/8" thick cement parging or an asphalt type coating will work as long as the ground water level doesn't get too high or put too much pressure on that wall.
From some of the other books, if back filling with gravel, at the bottom have the soil or the membrane if using one direct the water way from the wall.
I have used it to good success....Well... just looking to do a patch. The walls were coated black. So I will find something similar.
I did look up Drylok and it can be used outside and under grade. -even says for fish ponds, so I guess it holds water OK, lol
Hold my beer......
Hold my beer......
Is that a jack-o-lantern in bottom pick?Well have the pond and Gazebo lights working correctly off one remote.
I disconnected the lights from the solar panels, and let them charge all day in on position.
Shut the panels off manual switch, reconnected lights. Turned panels on. No problem, lights stayed off. Hit remote. Both go off and on together fine now.
On to the rest of the lights for the pond and waterfall tomorrow.
Nope actually 3 of them. Have to figure out why the other two don't light. They are old.Is that a jack-o-lantern in bottom pick?
