For what? i thought you coated it with Fluid FilmThink NAPA carries it.
Good Morning
Thought you wanted it for the mower deck. There used to be a dry graphite we used to use on spedo cables have no idea what it was called, worked well.At the new place, I have windows with a small spring mechanism at the bottom.
The windows roll in and out.
I was looking for a dry silicone spray to use on them.
Looks like several to choose from.
The lawn mower also.Thought you wanted it for the mower deck. There used to be a dry graphite we used to use on spedo cables have no idea what it was called, worked well.
I have had fluid film on my shelf for 20 plus years. Made from lanolin. Repels water, and staysI assume the graphite stuff is dark/black. Never used Fluid film, but sounds like its near clear. Graphite is good as lube where you don’t see it and don’t want buildup. Won’t attract dirt like grease. Definitely good for cables and roller chain.
The fluid film is a bit tan, but clear tan. Just makes the surface look kind of wet. Great on a used mower deck and blades, the slip pate great for new or rusted parts like exhaust manifolds, make them almost look like new.I assume the graphite stuff is dark/black. Never used Fluid film, but sounds like its near clear. Graphite is good as lube where you don’t see it and don’t want buildup. Won’t attract dirt like grease. Definitely good for cables and roller chain.
Disgusting but trueDid you see what she said? Her mom laughed and her dad thought it was cool. Dad's probably been all up in dat, yo. Good GAWD, what values!
I bought a gallon of slip plate and used on the GTS ex manifolds. They look new....The fluid film is a bit tan, but clear tan. Just makes the surface look kind of wet. Great on a used mower deck and blades, the slip pate great for new or rusted parts like exhaust manifolds, make them almost look like new.
Don't confuse Slip Plate with Anti Seize!I bought a gallon of slip plate and used on the GTS ex manifolds. They look new....
Chlorinated brake clean!So whats you favorite non-recreational chemical?
