For real?!? Geez wtfJudge agreed with us that she abandoned him, but gave her full share anyway. Probably going to appeal. That is likely going to tie it up for another year.
What switchI bet after that the switch is on the transmission...
Back up lightsWhat switch
Floor, column or push button (it does make a difference between 64-67)Back up lights
Floor.............Floor, column or push button (it does make a difference between 64-67)
Hopefully this one isn’t a swimming pool on wheelsSo Tim. Did you buy the Dart?
I see it sold for 9k
My barracuda console has a switch in it if i recall.Floor.............
Nope I passed..... My good friend Wolfie suggested I let it go....So Tim. Did you buy the Dart?
IMO it was too high priced. It will be listed again mark my word. The one bidder was a shill....So Tim. Did you buy the Dart?
So pan is off, tuned up some oul pump interference. Learned what year the 360 is thanks @krazykuda for the info, 1/9/78. Was going to do timing chain, but it will have to wait…View attachment 1715748669
Yeah. Able to do up 26 in diameter logs up to 18 ft long.
Have to remove the left sill plate, the left kick panel, then put a jumper across the connector to the switch. Hope it is not the switch.....Floor, column or push button (it does make a difference between 64-67)
Has a thermoquad already. New chain just went on. Compression seems decent turning it over by hand. New water pump in morning. Forgot to order a ecu harness. Have to see if i can fibd a part number.That will work fine in the Fargo...
Toss in a timing chain, small cam, and a 4 bbl and you're ready for a fun time....
If it is switch i will see if i can locate mine. I wont be needing it.Have to remove the left sill plate, the left kick panel, then put a jumper across the connector to the switch. Hope it is not the switch.....
15 days,I'll be back in America.15 days till I get off this boat.
Sorry I didnt backread but you got company coming back with you?15 days,I'll be back in America.
