I guess I better get moving on this. I have so much to do today I may just go back to bed.
If memory serves black is the power feed so the breaker off should open the circuit, white is the return and it ties into the ground at the box I believe. Ohm the black wire to the others and see if it is Shorted, If it goes to other things on outlets un plug them to get a good read on it.
Don't do that, this is an easy job inside and when you think the power is off plug a hair dryer or something up to it and double check, stay safe and enjoy coffee while you do it :cheers:I guess I better get moving on this. I have so much to do today I may just go back to bed.
i guess i better get moving on this. I have so much to do today i may just go back to bed.
How will he make coffee then?
I bet that the bathroom is hooked to the same breaker , so he would have to move his coffee pot to the living room I guess
I did put several circuits in everywhere.
For some reason I doubt he has a blow drier also. Plug in a 110 welder to test it! Hit the kitchen faucet with it to check the ground! LOL
The GFI is just before it. It has tripped a few times in the years but we are always having power surges and loss of power. But it could have been a problem before. The furnace is a trailer unit, not sure what it draws. And no the living room and bathroom is on their own circuit. Actually the living room has 2 circuits. I did put several circuits in everywhere.
Well I need to get rolling on this. Have a great day guys!
