I was hoping a box from you was going to show up when Dart was here yesterday!
I am always getting outbid...because....I'M CHEAP!
Did "your" knife come?
so how is the dart in your avatar doing ...its been a long time since I heard an update. Last I remember the slant six was acting up .....something was wrong.
And a plow did some damage.
Any other news/progress??
Good morning Memike!
My other sickness is motorcycles! Geesh what is wrong with me?
It looks like it will be here today!
Motorcycles is one thing I never understood, they are as far from safe as can be. :???:
I have a sister who is into motorcycles and knows the different types and all .....if she was in a position to work on them I bet she would but her location dictates that such thing will never happen :???:
Hey...anyone know if an electrical outlet can go bad after 20 years? I came home to no heat and found the problem is an outlet that the coffee pot was hooked up to. The furnace is on the same circuit. But it has been like this forever. man the outlet is melted. I almost burnt my house down.
Yes and yes, An outlet can loose the good contention the wires had as years go by and start heating up when a load is put on them, and the breaker can as well, pull the breaker and tighten up the lug that the wire is hooked up to.. I use to do safety inspections for OSHA and Hospitals , loose wires will create heat just like in our cars.. replace the breaker and the receptacle .Hey...anyone know if an electrical outlet can go bad after 20 years? I came home to no heat and found the problem is an outlet that the coffee pot was hooked up to. The furnace is on the same circuit. But it has been like this forever. man the outlet is melted. I almost burnt my house down.
Sounds like you got real lucky. If the outlet is melted it probably started right there. I would check it out really well and ohm the wires to look for a short in the run.
Good call. It happened because he touched the firechicken yesterday!
I#-o swear Not a southern thing just a (Got in a hurry) thangYes and yes, An outlet can loose the good contention
A southern thing?
