Last night's roast beef, potatoes, and carrots is delicious!
the filter is fine, It pumps great when I disconnect the line and squirt it into a bottle.Do you have a filter before the carb?. Or perhaps float has inlet valve stuck in closed position ?
Float may be stuck in the up position, or needle and seat stuck closed. Tap on the carb inlet " lightly" ......the filter is fine, It pumps great when I disconnect the line and squirt it into a bottle.
I will look how to check they inlet valve
https://photos.app.goo.gl/Ew4iEdfoyvmoYK1y7Float may be stuck in the up position, or needle and seat stuck closed. Tap on the carb inlet " lightly" ......
Thank you! I guess it was a little sticky from sitting on a shelf since 2018.Float may be stuck in the up position, or needle and seat stuck closed. Tap on the carb inlet " lightly" ......
No.ok......
I'll put it on the coil for now, I'll buy a relay and wire it proper after this weekend
its a 70 with ZERO optionsNo.
Coil gets reduced voltage.
Put a piggyback on the run circuit before the current goes through the resistor.
What year is your car?
Electric assist for chokes started around '72 or 73. Just use that.
If it doesn't draw much you'll be fine.
and the ammeter will read correctly.
ok, I can do that tomorrow.Never mind I check your profile. 1970 doubt it had the choke assist.
put a piggy back on the at the ballast resistor. done.
I'm sitting in the parking lot of the sports plex waiting for my wife to get done walking. I hopped in the car to come out and get her from the office in my ROBE AND SLIPPERS and she wanted me to go walk. No way I said
I wasn't counting you your up well should be...I'm still here......Only 6:42 pm here. Lots of evening left....
Yup, I love it here. Service like no other place in the World ...Mitch looks like you're having your usual great time.
Had a real nice glass of CA Phe da ( iced black with only sugar) at my favorite Cafe today.
Just got back home from Saigon. Time for a few cold Beers and maybe a dip..
View attachment 1715859670 View attachment 1715859671
True story. Coffee is so strong here, you dare not drink before breakfast. One time, years ago, I did just that. Two glasses of iced coffee. Had a racing pulse and heart murmurs for an hour. Learned my lesson.....Coffee is strong here, snow flurries going on outside.
Good morning Z and Mitch
