Morning all. Off Freeport, Tx. Dodging weather again.
I have a guy for that.Love the changing seasons here. Just think - in a couple months we can ***** about having to mow the grass!
Good Morning
Add on that it looks like black dirt after a day of people driving.That was a bonus in Colorado. Get a bunch of snow but then the sun comes out and if it doesn't outright melt it off being outside isn't that bad even when it's cold. Here in the east... gray nasty and the first snow to fall is often the last one to melt. Can be depressing. I really enjoy outdoor winter sports but there's nothing you can do with 2 inches of patchy crap ice stuff like this
So these are the specs I am hoping to achieveIf they are good it's worth it.
I’m curious to see if it holds up . They said it will “cure” the day before the cars hit the track...
Me too. I usually don't back read. don't do a very good job of catching up either. LOL
https://photos.app.goo.gl/rr9mRTKhcQy5t3uV7
Took er out to the desert yesterday to do some senior pictures.
i'm suprised it held up the whole day. I beat the crap out of it
oh yeah!Uncorked?
I'll ask Dave!So these are the specs I am hoping to achieve
Camber, -.5 Degree. Castor +2.5 Degree. Toe in 1/16 to 1/8. Look right to you guys? Or do you know....
I have a question...Uncorked?
Does it sound cammed to you guys?
at idle it has low vacuum, and it is pretty poppy and lopey at idle too.
I have never touched it, but when I did a compression check it had 120psi on all cylinders and it had fel-pro gaskets already on it when I changed the intake. It did come out of a 70 satellite roadrunner clone. to me, all those things don't add up for a '73 318.
no, it has a 4 barrel and a '71 340 intake on itMy swinger was the same way. With the 2bbl it sounded pretty lumpy. Put the Air Gap and 4bbl on it, smoothed right out .
which is why I think it has a cam in it. because with everything fixed, it should not be that lumpy and shaky.no, it has a 4 barrel and a '71 340 intake on it
My two best friends growing up, but really, there are lots of reasons for lumpy and shaky that has little to do with cam grind. Is the cam installed straight up? Do you know what that means..... Low vacuum on a stock engine is suspect IMO. But I was the guy who told you to wire the choke off the coil. So there is that...lumpy and shaky.
I never touched the cam. the only thing I have done to that motor is change the intake and carb. the guy I bought it off of pulled it out of a satellite he just bought the week prior. so he does not know anything about it. just based off of what my other car buddies have said, and seeing how at least the intake and front cover have been off,(silicone sealer on the cover) I think it could have at least an RV cam. no vacuum leaks, timing is correct, and Tuesday I am getting a new dizzy vacuum canister so I can hook up vacuum advance. (and yes I know what installed straight up means).My two best friends growing up, but really, there are lots of reasons for lumpy and shaky that has little to do with cam grind. Is the cam installed straight up? Do you know what that means..... Low vacuum on a stock engine is suspect IMO. But I was the guy who told you to wire the choke off the coil. So there is that...
Every Dirty Girl has her secrets.I never touched the cam. the only thing I have done to that motor is change the intake and carb. the guy I bought it off of pulled it out of a satellite he just bought the week prior. so he does not know anything about it. just based off of what my other car buddies have said, and seeing how at least the intake and front cover have been off,(silicone sealer on the cover) I think it could have at least an RV cam. no vacuum leaks, timing is correct, and Tuesday I am getting a new dizzy vacuum canister so I can hook up vacuum advance. (and yes I know what installed straight up means).
yeah, Im fine with it. the only thing I'm not fine with is it leaking water from behind the intake and I can't tell where it's coming from.Every Dirty Girl has her secrets.
If she's hot, runs good, and shows you a good time, don't worry about it, would be my advice.
Mopar is hiring. A chief donut maker. For real. Anyone can apply....
That has been out for a while, but I can't find where to apply. $150K/year and will work around your current job - promoting the Hellcat."Here's How to Apply for Dodge's 'Chief Donut Maker' Job and a Free Hellcat" Here's How to Apply for Dodge's 'Chief Donut Maker' Job and a Free Hellcat
The Job – Chief Donut Maker | DodgeGarage
**Edit: Much more info than when it was first announced.
