YoHey Keefer and Timmy!
Who us?Mornin feckers.
Lam roi....Mornin feckers.
What is it with Mustang guys? Its no wonder they get the reckless driving rep. Was just at the grocery store. Coming home its 32F and light rain - could go icy at any time. Most are driving very careful. Newer Mustang taking a right in main intersection gunning the gas through the turn. No, he didn't actually break the tires loose. Just made noise and backed off a couple times But really? We know you have some power. You could f'kin idle your way around the corner....
Wheres the fun in that?What is it with Mustang guys? Its no wonder they get the reckless driving rep. Was just at the grocery store. Coming home its 32F and light rain - could go icy at any time. Most are driving very careful. Newer Mustang taking a right in main intersection gunning the gas through the turn. No, he didn't actually break the tires loose. Just made noise and backed off a couple times But really? We know you have some power. You could f'kin idle your way around the corner....
My barracuda smells like a coolant leak if its gets hot enough. My temporary solution is ginger pills. The ones from a GM dealer supposed to be the best. Barr's sells a version thats at most local stores.My Wife and Mom took my car in for a heater core change Tuesday. Dealership called and cant find a leak. Told them if you go anywhere past mid temp towards hot on hvac controls you smell coolant inside the car and you lose coolant from the radiator. They are still trying to find the leak. Will call me back on Monday.
At least the carpet is dry.
Yeh, just not in traffic when a lot of people are on edge with the weather changing already. Go down an empty back road and open it up straight into a ditch if it makes em happy...Wheres the fun in that?
My problem is I drive it 500 miles one way to work when the boat is working stateside. I have already blown the head gaskets once from an overheat due to a cooling fan failure. Torque to yield bolts and ARP was out of stock at the time.My barracuda smells like a coolant leak if its gets hot enough. My temporary solution is ginger pills. The ones from a GM dealer supposed to be the best. Barr's sells a version thats at most local stores.
Clamp meter didn't work today. I've hardly used it. Worked a couple weeks ago. dunno.
I'll see if Innova has any customer service worth wasting time with.
jeep's electrics seem to be working more or less to spec. Just going by voltage and voltage drop. Should be OK for now. Some small things to fix, but no rush.
That's a long drive with that smell and worry.My problem is I drive it 500 miles one way to work when the boat is working stateside. I have already blown the head gaskets once from an overheat due to a cooling fan failure. Torque to yield bolts and ARP was out of stock at the time.
I don't see itAgainst the law here but they usually let it slide. Unless they don't.
Yep, electronics can flake out. (as you well know) I sold Innova timing lights for many years without an issue. I just bought one of their cheapie scan tools for a buck fiddy from the parts store. It seems to work fine. It has a battery/alternator test which is pretty cool. No specs just a pass/fail.Not that anyone cares. Called Innova and they had no service or a way test the clamp meter.
Then while looking wat the meter a connection was made.
The meter responds to current in millivolts. There's two settings. 1mV per amp and 10 mV per amp.
So duh, to see if the clamp meter is working, connect it to the multimeter's voltage setting.
So the clamp meter is fine. Therefore its the multimeter's built in mV to amps converter that doesn't work.
Not that the math is that difficult. I can multiply by 10 but the meter is starting to get a little flakey so I bought a new one.
Happens to be on sale at Innova's website, shipping included in the price.
Good deal if anyone has been thinking about a low cost, reasonably decent automotive multimeter.
Automotive DMM 3340
I'll give them this. They answered the phone pretty quick and the guy spoke standard American English.Yep, electronics can flake out. (as you well know) I sold Innova timing lights for many years without an issue. I just bought one of their cheapie scan tools for a buck fiddy from the parts store. It seems to work fine. It has a battery/alternator test which is pretty cool. No specs just a pass/fail.
Who ya hiding from?Getting windows on dart tinted. I think...
You guysWho ya hiding from?
oh man ! I can relate because I am NOT attempting to drive down my driveway because totally slick smooth solid ice. I believe it will thaw by tomorrow evening ot Sunday. Fingers crossedTotally black ice here. Stuck till it defrosts, even the road is all Ice!
you are a smart fellow TimYou guys
I am planning on doing those zoomies on my duster.
Just got to work a bit early. Roads were mostly OK. Rain had stopped for long enough to drain pretty good. Now drizzling again. Getting some icy spots…Totally black ice here. Stuck till it defrosts, even the road is all Ice!
