Its like 27f here now. Ice is melting off the deck!18 deg and snowing here. Bacon and eggs for breakfast.
NiceThen this slides over the 2 inch cross tubing, welds to it. Trim the top....
You trusting just sheet metal?!Only had to drill these two holes thru the sheet metal in trunk. No holes were drilled thru frame rails.
We have a few piles from plowing around town but that's it. Chance of a couple inches tonight?So, was meter reading day. Its just above my tall winter boots.middle of kneecap. Can see where i lost my balance due to the leg issue. Managed to not fall down. View attachment 1715883343
1/4 inch plate on top. Using existing holes in the frame rails...You trusting just sheet metal?!
I probably did. (bad influence) It is good. If you like a sherry cask finish try theirs. It is delicious as well. Daringer is the name I believe.Too much to bad read. Tried this today. I think @toolmanmike told me about this one. Delicious!!
Nobody reads meters around here anymore. From what I understand, they basically a cell phone embedded in them to read remotely.So, was meter reading day. Its just above my tall winter boots.middle of kneecap. Can see where i lost my balance due to the leg issue. Managed to not fall down. View attachment 1715883343
Showed Cheryl and she replied that was awful...lol!!So like Frank, we still have a couple of feet of snow on ground. If you look close you can just see the tippy top of our Adirondack chair poking thru the snow. The Adirondack chair at our fire pit along with the shovel stuck in the ground is our snow gauge! And the rabbit hole is exactly what TMM was describing, aged in Sherry cask yummy!
That’s why I can’t hardly drag Jodi out of Ark this winter. She is talking about coming home later this month for a booty call! Hah!Showed Cheryl and she replied that was awful...lol!!
Its the same here, i had a tractor with a snowblower that needed repair and blew that trail out in jan. So its not as deep there.Showed Cheryl and she replied that was awful...lol!!
Yuck!So like Frank, we still have a couple of feet of snow on ground. If you look close you can just see the tippy top of our Adirondack chair poking thru the snow. The Adirondack chair at our fire pit along with the shovel stuck in the ground is our snow gauge! And the rabbit hole is exactly what TMM was describing, aged in Sherry cask yummy!
Liquor? Cream filled beaver? Anyone I know? What's not to like!
Oh no! What happened? YOu ok? (obviously not)
