Pop, sizzle, they will make noise but you may not hear.So nothing would pop first?
So I’m wondering if I should swap out the harness in my 64 Polara then to a later model with the fusible link since I have to replace the under hood harness after my fuel fire
Yeah once hahaEver see a battery used as an arcwelder?
It will be a lot easier to just wire in a fusible link.So I’m wondering if I should swap out the harness in my 64 Polara then to a later model with the fusible link since I have to replace the under hood harness after my fuel fire
Off to YouTubeIt will be a lot easier to just wire in a fusible link.
Don't make me put you on Ignore!Off to YouTube
Darker wood? Que @krazykudaYep just like that but I want darker wood!
Thanks!Don't make me put you on Ignore!
https://www.oreillyauto.com/shop/b/...17516/12af23bde667?prodAttr_13710_ss=16+Gauge
https://www.rosevillemoparts.com/?s=fusible+link&product_cat=0&post_type=product
ps edited my previous post
Can’t use that kind of grip, had them on my 29, just to small.A little revolver love for you boys! Match day with revolver
Agree, on my 29s I use a different grip. The pictured revolver is a 22. That grip helps me grab it same way every time.Can’t use that kind of grip, had them on my 29, just to small.
OHHHH Karl...Yep just like that but I want darker wood!
Back in the day when I carried a 357 at work I had very similar grips like that.Agree, on my 29s I use a different grip. The pictured revolver is a 22. That grip helps me grab it same way every time.
You mean intentionally, or ?Ever see a battery used as an arcwelder?
Or....You mean intentionally, or ?
Went back to the factory wood grips on mine.Agree, on my 29s I use a different grip. The pictured revolver is a 22. That grip helps me grab it same way every time.
I do like wood! Hah! I also shoot a pair of Dan Wessons which have some of the most beautiful grips ever on them. I put spalted maple on my 45s and I really like that as well. (Pix)Went back to the factory wood grips on mine.
Looked at one of those, though the 357 was a little hot for such a light pistol, 38 might be more controllable.while at the gun store today, I looked for that 357 today. It was already sold.
I looked online tonight and a S&W 357 340 PD hammerless J frame (light weight) with a 1.875 barrel looked interesting.
Talk about a nice little pocket gun that with the right ammo could do some convincing.
Hey John, @Sublime one Here's a sign you need above the toilet in your new bar! View attachment 1715886443
it was the fusible link! Thanks all
So just curious , if that happens on a non fusible link cars, like my Polara, what would happen?
