tomorrow imLeave em alone...
Gonna torque the heads down and install the lifters and rockers , then measure for the push rods and get them on order.
Those the heads I picked up for you?tomorrow im
Yes sirThose the heads I picked up for you?
What head gaskets you using?Yes sir
Whatever the felpro part number that Eddy had in their instruction book. 1009 or something like that, I’ll have to double check.What head gaskets you using?
Spray them with copper gasket spray. A good deal....Whatever the felpro part number that Eddy had in their instruction book. 1009 or something like that, I’ll have to double check.
I also have a set of Mopar performance brand head gaskets too.What head gaskets you using?
I’ll do that before final assembly. I’m still waiting on my valves to come in. Freaking back ordered...Spray them with copper gasket spray. A good deal....
You do know you have to replace the head gaskets after you take them back off, right?I’ll do that before final assembly. I’m still waiting on my valves to come in. Freaking back ordered...
So I’m gonna torque these down and get everything measured up for the pushrods, then pull them back off. get those on order just in case they’re on back order too
Yep yep. And I’m using new ARP head studs for the final assembly too. Tomorrow’s torque down will be done with the new ARP head bolts for RPM heads.You do know you have to replace the head gaskets after you take them back off, right?
Question, would full on copper gaskets be worth it?You do know you have to replace the head gaskets after you take them back off, right?
Nope. Will leak water. IMO those are only used in dry engines....Just my opinion...with serious boost, SERIOUS boost!!Question, would full on copper gaskets be worth it?
He saw it on the boobtube. What would us guys know? If you had never done something you'ld be sharing it too!My money is it will not eat grease...
Good to knowNope. Will leak water. IMO those are only used in dry engines....Just my opinion...with serious boost, SERIOUS boost!!
Actually no, I was actually researching science fair projects for my daughter’s science fair coming up after spring break. She has to do a project involving “house hold kitchen supplies.” Figured I’d tackle two birds with one stone.He saw it on the boobtube. What would us guys know? If you had never done something you'ld be sharing it too!
When the stove has that much grease, start with a household scraper.Actually no, I was actually researching science fair projects for my daughter’s science fair coming up after spring break. She has to do a project involving “house hold kitchen supplies.” Figured I’d tackle two birds with one stone.
Nice!When the stove has that much grease, start with a household scraper.
Ammonia will lift grease and wax if you use it right.
Vinegar is a pretty good cleaner, but its just a mild acid.
Isn't that special.Just "talked to DDaddy" He said he might show up at the show in Carlisle. Cool. He is quite busy with his new business...
Hey Ray....Where ya been. Missed yaIsn't that special.
Getting my ankle repaired and a few other things.Hey Ray....Where ya been. Missed ya
