Well worth it! Good time to change the water filter out if you have a ice maker.
Wow! That’s crazy. I’ll have to try that. And yeah, thicker gasket lowers the compression ratio a tad. I’d ordered my pair of felpros from Summit racing so that’ll be an interesting comparisonTry this experiment...buy the same exact gaskets at NAPA and then go to advance Auto. Check the difference. You don't even need a Micrometer. NAPA is heavier and thicker. Unless there was a mistake in packaging at Advanced they are cheaper. And the thickness should effect performance to a certain level
Our's needs replaced and it is built in. It will be a major remodel when we need to replace it.The man or lady that is delivering it will put it in place and move the old one out to the shop, not bad for 50 dollar charge
They can suck sometimes. I tell you what that kit for the front end is great. That tool you mount on the T bar and hit with a big arse hammer is great. Glad Dean has one that I can borrow. Makes life so much easier with all the bushings etc.
Dam since I am lazy, and do not back read what happened to OMR?
Ouch. Really hope the new K member will fix it.
So anyone know of anyone that specializes in mobile swimming pools
Wow, I would say so, hopefully that fridge hangs in there for 30 more years, we are getting a much needed bigger one, wife and I have been living out of a med size fridge and now have a side by side, sounds like a sports mud unit side by side...Our's needs replaced and it is built in. It will be a major remodel when we need to replace it.
You can but the frig we are looking at is a 3 door with ice and water in the door. Believe it or not, Sub Zero still makes one like ours. it run's around $15,000 and doesn't even come with a ice maker.Any way to pull the panels off?
You are getting expensive. K member, Strut rods, torsion bars, LCA pivots then a bushing for them. Go with PST o the bushings, good stuff. Doing the upper control arms also?
We have been here almost 30 years and the kitchen was remodeled many years before. They built them to last back then.Wow, I would say so, hopefully that fridge hangs in there for 30 more years, we are getting a much needed bigger one, wife and I have been living out of a med size fridge and now have a side by side, sounds like a sports mud unit side by side...
Holy Molly ! Should come with a ice maker, water dispenser and a short skirt maid ..You can but the frig we are looking at is a 3 door with ice and water in the door. Believe it or not, Sub Zero still makes one like ours. it run's around $15,000 and doesn't even come with a ice maker.
Good to know. I tried a can of that but wasn't impressed. Right stuff for certain jobs!Rusted into the LCA... freaking struggle getting it out but that CRC Freeze did the trick. @krazykuda gave me the idea when he mentioned heating it again and dousing with ice water
Looks like someones project from FABO ?
That is cheap actually. Definately check the LCA pivots out
True that, the fridge we have here has been with the wife and I 30 plus years, its going to continue working for us in the shop.We have been here almost 30 years and the kitchen was remodeled many years before. They built them to last back then.
I just looked the model number up. They were made from 1972- 1987 so ours is at least 35 years old. I would have to dig to find out when the kitchen was remodeled by the previous owners of the house.Wow, I would say so, hopefully that fridge hangs in there for 30 more years, we are getting a much needed bigger one, wife and I have been living out of a med size fridge and now have a side by side, sounds like a sports mud unit side by side...
