shittyslant6
ok so last check before I start it,I have none in my 66...
this should work?
That will work.......
Other than insulating it.fire hazard.
yeah that's the next stepOther than insulating it.fire hazard.
I think I held it with vice grips and pressed it out with a shop press.....Or a cold chisel and cut it off....That is what I did. Put pivot in bench vice, used a cold chisel, and hammer, and pushed it off...
they are fun. Didnt that kit have the remover for them?
And here also. Weekend and following week are back in the 70's...hopefully for good!!Yes it is. Another chilly rainy day here again!
Never heard of it. Do you buy it at the feed store or box stores??Credit 41 works great and safer than round up.
Just weed control. Don't want to kill the grass.Kills everything. What are you trying to do?
Credit will work great on the brush and a real Kill of the weeds, not sure how long after application before you can plant on the treated area.Down in the meadow we call it three acres we have a lot of thick pasture grass. That's great no weeds.
About a third isn't and has weeds. Going to kill off the weeds this summer and plant a hearty low growing grass.
I don't plan on mowing it. We also have a lot of matured trees with the scrub brush growing around them.
Going to cut it all out and spray it with something so it doesn't come back.
Overall, just clean it up, never have to mow it, and enjoy the view.
Ya I'll go out to our local farm store. Spray is usually cheaper there.They make selective herbicides for that. Stuff like dandilions use the scotts weed and feed in the spring. Round up is non selective also.
I planted Centiped grass in HI. That was great never got over a inch and choked everything out. Think it cannot freeze though.Down in the meadow we call it three acres we have a lot of thick pasture grass. That's great no weeds.
