Really? I just helped my buddy with his 413 swapped 68 dart, fender well headers and we got the master on in that no problem. 75 dart disc set upCannot get master to fit with the 440!!!!
Can’t wait to see pics of thisNo been garaged. He is selling his house, has to move everything....
I used hooker headers. complete under chassis. Tight fit ill tell you.....Might need to be replaced.....Really? I just helped my buddy with his 413 swapped 68 dart, fender well headers and we got the master on in that no problem. 75 dart disc set up
That setup you can use the master cylinder offset bracket that is easily available. We couldn’t with fender Wells.I used hooker headers. complete under chassis. Tight fit ill tell you.....Might need to be replaced.....
He wanted to use a power brake setup....That setup you can use the master cylinder offset bracket that is easily available. We couldn’t with fender Wells.
Can still be done. Heck, I’d look into a hydro boost. I’m thinking about it, but I’m thinking of doing it on its own PS pump so each system is separateHe wanted to use a power brake setup....
We call that goop in this house.No real idea what this is but it contains old deer burger from back of freezer (5 yrs old) frozen green chili’s from last years garden. Red beans, onions, and a bit of rice. Plus the obligatory can of hot Rotel. I will let that simmer for a bit to thicken up then fold it into a tortilla! I will eat out of that pan all weekend long!
Is that Extra gold?Beer run!!
Hah! We call it gruel!We call that goop in this house.
That a double date in VN?
Very creative![]()
Since nobody guessed, this is the movie, Quinton Tarantino's Reservoir Dogs
Stealers Wheel...
Gerry Rafferty was a member.
Morning gang
So met up with Demonic yesterday to get that scope. Freaking traffic getting into the fairgrounds are was bad. Worked out actually called him he was about a mile behind me so I pulled over we met up and put the scope and meters into the R/T. When we got there and found parking it was pretty busy inside a ton of Ford and GM stuff almost no Mopar. Vertigo crap was starting to hit so left around 1030. Did find a few goodies fast.
