Stop in for a cup of coffee
Tike how bad is the poison by you, out of control around here so far.
We have it here also but again we're in the country.
I'm always careful wear gloves when working in the woods wash up with soap and water when I'm in for lunch and done for the day.
I use a weed spray it seems to get rid of it.
Never had it yet.
I downsized from 12 acres to 1 acre. Way easier. No chainsaw time.. just riding mower now and that's almost fun with a headset and podcast going
XJtYXJrX2ltZy8xNzExMTQyNy9kZWZhdWx0LnBuZz94LW9zcy1wcm9jZXNzPWltYWdlL3Jlc2l6ZSxQXzk5,g_nw,x_0,y_0.jpg
Someone needs to mow mine soon. :steering:
My oldest has my pick up so I can't haul the rider over to my house. I'll have to use the push mower. :BangHead::BangHead::BangHead: THe lot is a half acre. Take out the house, garage and concrete.
Looking for a recommendation.
Drilled a couple small holes last fall through the brick garage walls to run a small pvc line outside for drainage off the mini-splits air/heat. Looking to fill the gap at either ends so small bugs/snakes don't wander in.
Is there a foam spray that will seal it up or do I use like a concreate caulk??
