I would use calk, spray foam can let the critters chew through.
I would use calk.Looking for a recommendation.
Drilled a couple small holes last fall through the brick garage walls to run a small pvc line outside for drainage off the mini-splits air/heat. Looking to fill the gap at either ends so small bugs/snakes don't wander in.
Is there a foam spray that will seal it up or do I use like a concreate caulk??
I didn't use any salt. That's supposed to make it more of a 'ground clear' that gets into the soil and keeps killing. I didn't want that since I was ready to put in the garden. With about 15% vinegar everything browned up quick and was dead the next day. The bigger dandilions with deep roots were coming back a week later so I dug some most of them out when I planted.I mixed up vinegar soap and salt. We will see how well it works. Keith says it does
Oh no...you didn't say that. LOLHolding hands with Dave.
I want this to be permeant Round up is crapI didn't use any salt. That's supposed to make it more of a 'ground clear' that gets into the soil and keeps killing. I didn't want that since I was ready to put in the garden. With about 15% vinegar everything browned up quick and was dead the next day. The bigger dandilions with deep roots were coming back a week later so I dug some most of them out when I planted.
Yep. Caulk. If I use spray foam for a bigger opening, I still coat it like 1/4" with caulk.I would use calk, spray foam can let the critters chew through.
I figured plumbers used something like that. I was picking up the landscape stuff at Mernards the other day and asked.I've had success with spray foam. Critters don't seem to eat it. I also put wire mesh over the end of the drain line to limit entry.
How much of each? What was your recipe?I didn't use any salt. That's supposed to make it more of a 'ground clear' that gets into the soil and keeps killing. I didn't want that since I was ready to put in the garden. With about 15% vinegar everything browned up quick and was dead the next day. The bigger dandilions with deep roots were coming back a week later so I dug some most of them out when I planted.
Which spray foam??Yep. Caulk. If I use spray foam for a bigger opening, I still coat it like 1/4" with caulk.
Ortho Ground Clear used to be the **** for that. Haven't used for years, cause NOTHING would grow there for a long time. Don't know if the formula is still the same.I want this to be permeant Round up is crap
Credit 41 will do it for sure. Lasts a year. How much mix will you use?I want this to be permeant Round up is crap
As said 15% vinegar. I got 30% from cleaning aisle in Home Depot and cut in half with water. Not sure how much salt is needed if you go that route.How much of each? What was your recipe?
I usually get Great Stuff. They have a bunch of different ones depending how much you want to fill. Just looked on HD site and I see they have one that is supposed to reppel critters, but I've never seen that to be a problem. Now, depending on location, BIRDS can be an issue. They will pick at it. Used to pick our valve insulation apart on the ammonia pipes at the cold storage,Which spray foam??
Where do you get that?Credit 41 will do it for sure. Lasts a year. How much mix will you use?
Which spray foam??
They had some concreate mix crap. I mentioned a foam spray and they had no clue. Remember what you used??
I have to paint the pipes first before I seal them. Ya I know a little anal...like it to look nice.
Great Foam, depending on the gap size there are varying "recipes" on expansion. If you decide on caulk or concrete injection I'd put some backer rod in and top off. I find that caulk is less effective on wider gaps or vertical surfaces.
FYI. This is not a budget solution. More of a way around nasty chemicals. The high test vinegar was like $20 a gallon. I’m pretty sure the Spectracide concentrate I normally get works out to much cheaper.As said 15% vinegar. I got 30% from cleaning aisle in Home Depot and cut in half with water. Not sure how much salt is needed if you go that route.
I use cement allWhich spray foam??
Well I could have said something else.Oh no...you didn't say that. LOL
