dukeboy440
Welcome to 2022, where nobody can get anything to stock. One of our suppliers on Monday had 4834 ECPs, today, completely sold out. 6 month lead timeNobody stocks anything anymore.
So I’m another Chris moment, I screwed up. Was installing the oil pump today on the 440 and noticed at the bottom of the instructions, it reads “This is a high volume, standard PSI oil pump. Requires a wet sump and 7 quart capacity oil pan”… so much for that stock A body big block oil pan
ECP? Electronic Crack Pipe?Welcome to 2022, where nobody can get anything to stock. One of our suppliers on Monday had 4834 ECPs, today, completely sold out. 6 month lead time
Electronic Circuit Protector. Used to 3 phase electric motorsECP? Electronic Crack Pipe?
That’s part of the plan. Trying to decide if I trust the electric valve or if I’d want mechanicalthis could be a useful addition that eases that issue View attachment 1715942675
https://search.aol.com/click/_ylt=Awr9Dth4bqpin8IA8RNpCWVH;_ylu=Y29sbwNncTEEcG9zAzIEdnRpZAMEc2VjA3Ny/RV=2/RE=1655365368/RO=10/RU=https://www.merlinmotorsport.co.uk/knowledge_base_articles/view/accusump-oil-accumulators-how-do-they-work-281/RK=0/RS=j1qSD7LG_6wkp1Hdvpvu29I8iRU-
Accusump oil accumulator
I have come up with a solution already. One will be fun to do, the other I was planning on anyway, that being an accumulator
Yeah but man oh man are those things expensive! 700 bucks if you go electricSome kinda Vulcan Mind Meld or sumthin
Don’t worry, I done came up with an idea.7"x7"x2" deep is almost 2 quarts View attachment 1715942682
Nah, the pan I need is 700 as well. Damned if I do, damned if I dont$300 and 3" less ground clearance from Summit for a big pan.
What pan do you haveYou should see the big dent in the pan on my 440 in the dart. Hangs down over an inch below the cross member...
No , I have an 85 Shovel Head...What pan do you have
How thick you need?
12 inches
That's what she said...
