Did i mention i got the cruise in and working? Its acting up a bit, takes a few seconds to kick in. Maybe cable is too slack.
Maybe needs more vacuum?Did i mention i got the cruise in and working? Its acting up a bit, takes a few seconds to kick in. Maybe cable is too slack.
Make sure the cable is tight but not to tight. Then a good vacuum source.Did i mention i got the cruise in and working? Its acting up a bit, takes a few seconds to kick in. Maybe cable is too slack.
Should slide right in.....Putting the torsion bars in now @Mopar Tim
I tried but when he blew RRR off for the nineteenth time I figured no point.You guys been following this one? Unbelievable! EMERGENCY HELP WANTED!
Yep, it really was not as bad as advertised. Only 96 but breezy. No IVs reqd. You got that car on the ground yet?You out of the sun?
I can agree with that. If its up around 15 it comes on. Wont engage if im driving into a headwind.Maybe needs more vacuum?
Maybe a canister will help?I can agree with that. If its up around 15 it comes on. Wont engage if im driving into a headwind.
This is my version of "right in" but I got it doneShould slide right in.....
Just so ya know I have never had a torsion bar not fight to the bitter end , coming or going out! Well not entirely true as I took a torch to last set! It was a short fight!
Well, For real, I have never had a fight. But I always remove the upper bump stop and push the upper control arm down as far as it will go......slide right in......Cue Karl!!!Just so ya know I have never had a torsion bar not fight to the bitter end , coming or going out! Well not entirely true as I took a torch to last set! It was a short fight!
I’ve only had two sets fight me, coincidentally both were in A bodies. All 3 chargers came out with no issue, same with the Polara which sat stupidly deep in mud for decadesWell, For real, I have never had a fight. But I always remove the upper bump stop and push the upper control arm down as far as it will go......slide right in......Cue Karl!!!
hmmmEvening. Spent the afternoon tearing apart my Grizzly 400. Thing just would not run, belching black smoke. Went and drained the tank, this is what I found. Mind you, this gas is just 12 days old. I’d ran her out of gas completely then. Anyway, 3 gallons drained out of the tank, right at 1 gallon of pure water came out of the bottom of this tank… then this was the rest, thing is stored inside.
I’m wondering if the station was just low that day or if another one is pumping water into their tanks. One of the BPs in town got caught doing that a while back.hmmm
