I find the hydraulic hoses for brake line’s interesting
But no idea what caused your original issue!Well I got the verdict on the Cummins head.
It’s not cracked but that’s where the good news ends.
Guides are shot, seats are shot. 700 bucks more for the rebuild. Gulp.
But better than 2500 for a new bare head
HD AC-High Altitude Rad. 2524962@memike and @toolmanmike What radiator did you go with on the 273 install?
I cannot remember the part number right off hand. But I had the Hemi radiator in my '68 Dart GTS 383 car. Original radiator as well. Very valuable radiator.HD AC-High Altitude Rad. 2524962
It’s possible although remote if the guides are cracked bad enough, it could be seeping coolant under pressureBut no idea what caused your original issue!
No clue
He said after he cleaned the head up real good and such, and comparing it to the gasket, he says he thinks the gasket let goI hate that...
"So, how do I avoid having this occur again?"
crickets....
Do you have a precision straight edge to check the deck for flatness?He said after he cleaned the head up real good and such, and comparing it to the gasket, he says he thinks the gasket let go
He’s gonna come out Saturday and use his while checking the block in the truckDo you have a precision straight edge to check the deck for flatness?
Plugged accel pump?Holly carb. Not double pumper. 680 cfm
Probably the California gasoline. Lol.Holly carb. Not double pumper. 680 cfm
The rust may have been helping it hahaProbably the California gasoline. Lol.
I got a new starter relay and it is different from the one on the car now. It is missing a blade, where this blue wire is connected and then connected on the wheel well. Do I not need this on the new one? Thanks
View attachment 1716085655The top one is battery , middle one is sol The one on bottom left is I for ignition and the one on bottom right is g for ground . I would think you need the ground .Hope it helps !
Yea weird !
