Not sure what is on the agenda for today…….. rain tomorrow and have new gutters getting installed tomorrow so we will immediately see how they work I guess.
pulleys are a pain in the ***.. i need to find a crank pulley for mine.. or just a matching set. wish i had grabbed the ones that were for sale on here a week or so agoThanks Mat..
Found a part number Engine Fan # 2463376... it's a 6 blade 17" so I can compare to the one I grabbed yesterday
Found a pulley on eBay. Still working on the spacer
Do you all have a new built house or just replacing??Not sure what is on the agenda for today…….. rain tomorrow and have new gutters getting installed tomorrow so we will immediately see how they work I guess.
YesAre crank pulleys balancer specific? Asking for a couple friends.
NoAre crank pulleys balancer specific? Asking for a couple friends.
MaybeAre crank pulleys balancer specific? Asking for a couple friends.
Depends on what the balancer chooses to identify asAre crank pulleys balancer specific? Asking for a couple friends.
What's the application on those?I think I am out of those 55KV coils, have to find more they go fast.
Thanks Mat..
Thanks. No not new, built in 2008. We are getting a new front porch with trex. The previous owner did not use pressure treated wood, not sure what they were thinking and one of the upper gutters drains directly onto the porch and major issues…..again WTF were they thinking.Do you all have a new built house or just replacing??
The pic you showed a couple weeks ago of your place with view looked great!!
And of course, the garage was top shelf also.
Nice digs!Thanks. No not new, built in 2008. We are getting a new front porch with trex. The previous owner did not use pressure treated wood, not sure what they were thinking and one of the upper gutters drains directly onto the porch and major issues…..again WTF were they thinking.
Anyway so 6” gutters, gutter guards and they will be properly installed and routed to not cause issues in the future, especially putting on a new front deck.
The left side of the porch where the screen room is where the problem is.
Then look it up and see what it goes with.
Certainly matches the '64 .
The codes for VC1 etc are probably in the begining
Still used in '65 with A/C
Doesn't seem to be in 1966 but maybe I missed it.
The 1966 FSM has one of these charts in the Service manual.
Maybe its in 65 or 64 or in supplement or Tech bulletin
Just looking at the A/C optioned engines, they got 7 blade fans, so no help there.
But the 6 blade fan shown also uses a 2" spacer. Now you can check the spacer p/n for 64 and 66 to see if they are the same.
Also we can figure out which water pump and pulley ratio these fans worked with.
It looks like only the thermal and viscous drive fans get the small impeller water pump and the faster pulley ratio.
On the concrete pad in front of the garage silly!Throwing rocks might not be great for burnouts
