well.. in fairness i wouldn't have touched them if 2 weren't rusted throughThats great. No one ever takes those plugs out when they flush a engine. Really gets crap out.
I have one of these you dont use it alot but really helps when you need to change them in a car.
Yeah, was just looking at the classified forum The price for new cast ones is a bit much for me to swallow.. the fabbed ones for $98 are a deal but scream 1978 camaro street racerI would put a add for valve covers might score some vintage cast ones. They are around.
tempest?Look on marketplace and tempest, they are around.
never heard of thatSearches all craigslists adds as far as you want. Scary actually.
mopar valve cover on SearchTempest
SearchTempest - search results for mopar valve cover on Facebook Marketplace (no affiliation), craigslist (no affiliation), eBay, and morewww.searchtempest.com
BrassI try to use the copper ones if I can, they seem to seat better and wont corrode. Seriously blow out the water jackets tons of crap in there. Pull the pipe plugs before you do it. Usually a inch of crap in there even after boiled out.
Thanks.Brass
Hoppy is the king of tempestReally crazy what you can find on there.
Alot depends on the lift and the baffle design to keep oil out of the breather and PCVi probably will.. just feeling lazy this morning.. woke up late...
Also wondering if these will clear the mancini/harland sharp rocker arms..
$77 doesn't sound too bad for them
Factroy design is pretty smart with hte angles - this one is for a small block
This one is also pretty well thought out
The little flat plate on the cast ones clears but isn't that effective.
