Take care of yourself Ray, kinda like having you around here.If Carlisle was today I wouldn't be able to go at all.
I can't ride that long. Or walk maybe more than 300 feet at a time without my legs getting tired, and that's on a flat surface.
Also fond of Teaser and the fire catTea for the Tillerman is one of my all time favorite albums. Followed closely by Buddha and the Chocolate Box!
Wow you are one busy dud!! Pup looks good.Finally got all the handrail posts in place. With appropriate gap for shooting bench incorporated into hand rail. The two posts sticking up on the backside are the beginning of the heckle bench. That is where spectators sit and heckle the shooter. Down below I have a bunch of the X bracing mitered and stuffed and wedged or staged for install.
They all do at some point. "Know when to walk away. Know when to run".Turning into a money pit, Dam thing otherwise is in great shape!
I often wake up too early (pain, birds, traffic....) regardless the reason, always gold to get back to sleep. Had two issues this week -poison ivy on left leg and right arm itching bad. And lower back not good. Mon and Tues I did a shot of Nyquil to knock me out. Usually only use it if really sick, but figuring the same stuff that works for a cold should help with the itch. Apparently it worked, cause I got 5-6 hours straight sleep both times. Just did Tylenol last night. Slept OK, but was up a couple times.Late start, unlike Ray, i did backread. Took a long time to fall asleep,maybe got 3 hrs in a row, went back to bed and got another 2.
Why you selling the duster?They all do at some point. "Know when to walk away. Know when to run".
That's why I bought a new car. Get away from that (for a while...). And, been trying to figure out how to get rid of the Duster with the least loss.
Thanks she has filled out nicely, she has put on about thirty pounds since we rescued her. And I don’t think she is an inch taller! She is trim and athletic now. I am having a terrible time keeping her from jumping off the deck. It is about ten ft to the ground. She is like a coiled spring all day! Thankfully with all the rain she is spending most of her time in the creek.Wow you are one busy dud!! Pup looks good.
I enjoyed the build, but not getting much out of it now. Just not something I want to perpetually spend time and money on. Paint is a mess. Some interior issues...Why you selling the duster?
Selling the duster are ye?They all do at some point. "Know when to walk away. Know when to run".
Gonna do a little work on it first, then will decide…Selling the duster are ye?
Looks awesome,one of these days I would like to sit on that deck. Pups are always full of piss and vinegar!So time for some lunch, stop get a bite and put on some dry clothes. I got the top rail done on handrail so the deck is much safer now!
I do know where your coming from....have to have fun with it its not...Gonna do a little work on it first, then will decide…
So whatcha going to have them do?Shop rate is $85/ hour
Thoughts on this? Keep in mind these are regional... so I figure where I'm located will be a bump higher than some places but not as expensive as others.
Buddy’s 50 chev is in shop. Im relaxing and he’s working on pulling transmission out.
Their hourly rate sounds reasonable. I charge $90 an hour in my shop to work on a customer's car. But the rate at the local shops around here is closer to 110 or $120Shop rate is $85/ hour
Sounds quite reasonable.Shop rate is $85/ hour
